Go to Post I also exclusively use FRC team numbers when punching in times for the microwave. - Calvin Hartley [more]
Unread 13-02-2015, 17:00
Re: Drive Backwards Causes A Rotation Movement
Originally Posted by tanogirl View Post
Forward=
Y = 1.000
Z = 0.008
Backwards =
Y = -1.000
Z = -0.0062
It's a small difference but it makes the robot rotate.
The above does not agree with your previous post:
When we pull the joystick backwards the Z axis has an input greater than the Y axis input.
