Go to Post ...your mentors are your friends. If you're not sure of something, they probably know the answer to it, and if they don't, they will point you to someone who does. - Karibou [more]
Unread 13-02-2015, 14:59
tanogirl's Avatar
tanogirl tanogirl is offline
AKA: Emma
FRC #3038 (ICE)
tanogirl is an unknown quantity at this point
Drive Backwards Causes A Rotation Movement
We are using the Logitech Extreme 30 Pro Joystick to control our mechanum drive base this year. Drive forward works fine and so does strafing. When we drive backwards the robot wants to rotate instead. We used smart dash board to locate the problem. When we pull the joystick backwards the Z axis has an input greater than the Y axis input.
Our Code is:
myRobot.MecanumDrive_Cartesian(stick.GetX(), stick.GetY(), stick.GetTwixt()/3, 0)
We divided the twist input by 3 to try to help with the problem. It helped a little but not much. Any ideas?
Unread 13-02-2015, 15:34
Re: Drive Backwards Causes A Rotation Movement
A twist-style joystick seems obvious for controlling a holonomic drivebase, but in practice it's just too easy to twist it by accident. My suggestion is to use a separate joystick for rotation control.
Unread 13-02-2015, 15:43
tanogirl's Avatar
AKA: Emma
FRC #3038 (ICE)
The problem is our driver gets confused when using two joysticks and prefers one
Unread 13-02-2015, 16:15
Please run a test and post the Z vs Y pairs for Y=0 to Y=max for several values of Y.
Unread 13-02-2015, 16:44
tanogirl's Avatar
AKA: Emma
FRC #3038 (ICE)
Forward=
Y = 1.000
Z = 0.008
Backwards =
Y = -1.000
Z = -0.0062
It's a small difference but it makes the robot rotate.
Unread 13-02-2015, 17:00
Forward=
Y = 1.000
Z = 0.008
Backwards =
Y = -1.000
Z = -0.0062
The above does not agree with your previous post:
Unread 13-02-2015, 17:23
tanogirl's Avatar
AKA: Emma
FRC #3038 (ICE)
Yes the Y axis is greater than the Z axis but the robot still rotates when driving backwards.
Unread 13-02-2015, 17:24
Please post results for Y=0, Y=.2, Y=.4, Y=.6, Y=.8;
repeat for negative Y commands.
If all the Z values are within +/-0.0099,
try adding deadband to your code:
if (fabs(Z)<.01) Z=0;
Unread 13-02-2015, 17:30
tanogirl's Avatar
AKA: Emma
FRC #3038 (ICE)
Where would you put that in the code?
Unread 13-02-2015, 17:32
Right after you read the joystick Z axis (i.e. before you use it).
