Go to Post Nutritionally speaking I didn't get enough (MOE) green in my FIRST diet this year! - Mark McLeod [more]
Unread 13-02-2015, 16:53
MegaQueen MegaQueen is offline
Captain of Team 1159
AKA: Samantha Bordador
FRC #1159 (Ramona Rampage)
Team Role: Driver
MegaQueen is an unknown quantity at this point
Difficulty Getting the Pulley to Move Down (Suspicions of a Programming Issue)
For our pulley we are using one motor that is programmed to move forward to lift and backwards to drop. It works fine while lifting, but the motor chokes while dropping. We tried to connect the motor directly to the battery and it worked perfectly both ways. But once the talon was connected to the power distribution panel, the pulley no longer flawlessly dropped. So now are suspicions have turned toward the programming. Do the talons understand the negative voltages/inputs to reverse the rotation of the motor? Or is there another possible way that this may be fixed?
Thank you!
Unread 13-02-2015, 16:59
kjohnson's Avatar
kjohnson kjohnson is offline
Insert Clever Title Here
AKA: Kyle J.
FRC #1610 (BOT)
kjohnson has a reputation beyond reputekjohnson has a reputation beyond reputekjohnson has a reputation beyond reputekjohnson has a reputation beyond reputekjohnson has a reputation beyond reputekjohnson has a reputation beyond reputekjohnson has a reputation beyond reputekjohnson has a reputation beyond reputekjohnson has a reputation beyond reputekjohnson has a reputation beyond reputekjohnson has a reputation beyond repute
Re: Difficulty Getting the Pulley to Move Down (Suspicions of a Programming Issue)
What do you mean by "chokes"? Does the motor not move at all? Does it pulse between moving and stopped?
Can you post a screenshot of the code controlling the motor?
Unread 13-02-2015, 19:50
You're using buttons, aren't you? Your code is almost certainly controlling the motor in two different places. The "down" part executes first, just by chance, and the "up" part immediately overrides it.
Unread 14-02-2015, 14:40
Team Role: Driver
Here's the case structure for what we are using and how our buttons are programmed.
Unread 14-02-2015, 16:57
Team Role: Driver
[quote=MegaQueen;1443996]Here's the case structure for what we are using and how our buttons are programmed.
We figured it out, we changed the case structure for different code.
