Go to Post In my line of work, we affectionately refer to this approach as "Seagull Engineering". Why? Because we swoop in, flap around making a lot of noise and commotion, leave a big mess of "stuff" behind and then fly off. - billbo911 [more]
Unread 13-02-2015, 19:51
Re: Error in Tank Drive code
If you want forward/reverse control on one joystick and left/right control on the other, you should be using ArcadeDrive instead of TankDrive.
