Go to Post OK, I may have heavily influenced their decision, but I would never kill a mentor for not choosing an event I was planning... maim maybe, but never kill! :D - KathieK [more]
Unread 13-02-2015, 17:57
BrighidKHeh's Avatar
BrighidKHeh BrighidKHeh is offline
FRC #3871 (Trojan Robotics)
BrighidKHeh is an unknown quantity at this point
Error Code???
Using Java and Eclipse. Every time that I completely removed all of the errors from a class, this error comes up at the top of EVERY page:
"edu.wpi.first.wpilij.tables.ITable cannot be resolved. It is indirectly from required .class files"
How do I get rid of this? I can't find it anywhere in the wpilij files like it says.
Unread 13-02-2015, 19:12
legts legts is offline
Autonomous Queen
FRC #2399 (The Fighting Unicorns)
legts is an unknown quantity at this point
Re: Error Code???
Have you made sure the wpi updates are all imported into Eclipse correctly? The link is here: http://wpilib.screenstepslive.com/s/...-all-languages. I can't really think of anything off the top of my head at the moment other then that. My team has run into a lot of Eclipse issues this season, but I haven't seen this! I'll see if there's anything anyone else can think of.
Lauren
Unread 13-02-2015, 19:15
Autonomous Queen
Re: Error Code???
Lauren
Completely ignore what I just said as it is 110% wrong. http://stackoverflow.com/questions/1...lved-it-is-ind is a link to a Stack Overflow post that is similar to your issue. It seems to have been resolved, hopefully some of the fixes posted there will help you! It's not FRC, but it is Eclipse and should help.
Lauren
Unread 13-02-2015, 20:35
Re: Error Code???
Eclipse just alerted me to two errors that aren't in the code:
#1: Project '2015TrojanCode ~ RecycleRush' is missing required Java Project '2015Code'
Resource: 2015TrojanCode
Type: Build Path Problem
#2: The project cannot be built until build path errors are resolved.
Recource: 2015TrojanCode
Type: Java Problem
Unread 13-02-2015, 21:23
JacobD's Avatar
JacobD JacobD is offline
AKA: Jacob
FRC #1672 (Mahwah Robo T-Birds)
JacobD is an unknown quantity at this point
Re: Error Code???
First check your USB/Network connections. If they are fine, try re-imaging the roboRIO and re-installing Java onto it.
Unread 13-02-2015, 22:38
Re: Error Code???
You seem to have something significantly broken in either your Eclipse setup or your project. Can you create a new project and try loading just the basic project onto the roboRIO and see if that works?
Unread 13-02-2015, 22:59
TFleig78's Avatar
TFleig78 TFleig78 is offline
AKA: Tyler
FRC #0078 (Air Strike)
TFleig78 will become famous soon enoughTFleig78 will become famous soon enough
Re: Error Code???
Type: Java Problem
I know we ran into problems when we started the name of a project with a number. rather than "2015TrojanCode" use "TrojanCode2015"
Unread 16-02-2015, 16:09
Re: Error Code???
I get an error when i attempt to rename the project.
