Go to Post And another big factor in winning. Luck. - Carol [more]
Unread 13-02-2015, 21:42
vasa.dhananjay vasa.dhananjay is offline
FRC #4748
vasa.dhananjay is an unknown quantity at this point
Re: First LabView Program - Trouble with motor control
I've tried with the voltmeter/oscilloscope and I LABVIEW probed some of the blocks when I did the example exercise and it seems to be setting the PWM to a value of 1537 . As far as I've delved into the internal blocks anyway. I'm not sure where to look to see if there are any issues with it actually setting the PWM to that value. The drive station hasn't spat out any errors either.
I just tried doing the arcade drive example. I can see that LABVIEW is reading the joystick values no problem but I get the following message when looking at the wire after declaring which PWM from the dropdown: PWM Channel | Not Executed.
Name:	PWM Not executed.png
