Go to Post Remember, if FIRST is your top priority, you need to look at your priorities. - Billfred [more]
Unread 13-02-2015, 21:23
gabrielc97's Avatar
gabrielc97 gabrielc97 is offline
AKA: Gabriel
FRC #4029 (Spartan Bots)
gabrielc97 is an unknown quantity at this point
How to add a button with new FRC Labview
Previously, you'd be able to unbundle the buttons cluster and give each button a function with case structures. Now, the data is an array. How can I go on to give the button a function?
Gabriel
Unread 13-02-2015, 21:47
Re: How to add a button with new FRC Labview
Instead of unbundling the button, you index the array element. Everything else from that point is the same.
Unread 14-02-2015, 07:45
Here are some examples
