Go to Post I am sorry if something was missed at your regional, it will be checked at this event. - Al Skierkiewicz [more]
Unread 13-02-2015, 21:44
StealthRobotics StealthRobotics is offline
FRC #4089
StealthRobotics is an unknown quantity at this point
Units of Speed for Talon SRX
The Talon SRX has a mode that allows use of PID to control speed. What unit is the speed? I would assume revolutions per minute, but I wanted to verify before I run the robot into any walls at high speeds. Thanks!
Unread 13-02-2015, 22:00
Re: Units of Speed for Talon SRX
The second paragraph of Section 17.1 of the TALON SRX Software Reference Manual says
The velocity units of a Quadrature Encoder is the change in Encoder Position per TvelMea
(TvelMeas=0.1sec). For example, if a US Digital Encoder (CPR=360) spins at 20 rotations per
second, this will result in a velocity of 2880 (28800 position units per second).
