Go to Post However, because they're programmers they just redid the interpolation tables for our motors as opposed to actually fixing the bent shooter. - Nuwanda [more]
Thread Tools Rating: Thread Rating: 8 votes, 5.00 average. Display Modes
  #76   Spotlight this post!
Unread 12-02-2015, 13:57
bEdhEd's Avatar
bEdhEd bEdhEd is offline
Design and Drive Team Mentor
AKA: Frank E.G. Shiner
FRC #0701 (The RoboVikes)
bEdhEd has a reputation beyond reputebEdhEd has a reputation beyond reputebEdhEd has a reputation beyond reputebEdhEd has a reputation beyond reputebEdhEd has a reputation beyond reputebEdhEd has a reputation beyond reputebEdhEd has a reputation beyond reputebEdhEd has a reputation beyond reputebEdhEd has a reputation beyond reputebEdhEd has a reputation beyond reputebEdhEd has a reputation beyond repute
Re: Unique robot design?
Originally Posted by IronicDeadBird View Post
I find that instead of slave driving find out who drivers have a crush on and have them stand nearby during drive practice and giggle and whisper.
Stage fright on steroids?
Possible acclimation technique to simulate on-field nervousness.
Productivity level: productive.
  #77   Spotlight this post!
Unread 12-02-2015, 17:07
carpedav000's Avatar
carpedav000 carpedav000 is offline
Studenting is hard, but worth it!
AKA: David Carpenter
no team (Jerry-Rigg school of DuctTapeology)
carpedav000 has a brilliant futurecarpedav000 has a brilliant futurecarpedav000 has a brilliant futurecarpedav000 has a brilliant futurecarpedav000 has a brilliant futurecarpedav000 has a brilliant futurecarpedav000 has a brilliant futurecarpedav000 has a brilliant futurecarpedav000 has a brilliant futurecarpedav000 has a brilliant futurecarpedav000 has a brilliant future
I would say that our robot is rather unique in two ways:
1.) It has 2 completely different lifts. One is a chain and hook system for stacking crates, one is a 4-bar for stacking containers and grabbing them off of the step.
2.) Our robot has two 45-degree angles in the front of the frame. This feature makes the crates self-align no matter what angle we are collecting from.
  #78   Spotlight this post!
Unread 12-02-2015, 17:20
who716's Avatar
who716 who716 is offline
AKA: Stephen Kalogiannis
FRC #0716 (Who'sCTEKS)
who716 is a splendid one to beholdwho716 is a splendid one to beholdwho716 is a splendid one to beholdwho716 is a splendid one to beholdwho716 is a splendid one to beholdwho716 is a splendid one to beholdwho716 is a splendid one to beholdwho716 is a splendid one to behold
Originally Posted by mrnoble View Post
It's possible that we are overly optimistic, but I assure you we wouldn't have troubled ourselves to incorporate it into our robot without the most realistic testing conditions we could make. On what is your pessimism based?
It's based on our teams testing of a very realistic field setup, we found it rather time consuming and power draining to move the totes by way of snowplow, we really had to run into them to make a slight movement, and if they were off center from one another it makes it that much more difficult then we tried over the top and can grab two containers in 2 seconds and by 4 seconds be in the auto zone with two of the gray tots from the landfill dragged behind.
Another issue is if you push the landfill to get the containr on the far left, you then have to to push the totes back were they were if you want to get the container on the far right
If you want to do coop and you have the landfill totes pushed to one side it going to be difficult to get a stack of four if the other alliance can't get to that center
-WPI number one seed
-Innovation in controls award
- NECMP#4 seed semifinalist
- 9th in NEW ENGLAND
2008- Connecticut regional winners
2004-UTC new England regional Winners
2001 highest rookie seed award winner
  #79   Spotlight this post!
Unread 12-02-2015, 17:24
Thromgord's Avatar
Thromgord Thromgord is offline
The Warlord
FRC #3807 (The BlazerBots)
Team Role: Marketing
Thromgord has a spectacular aura aboutThromgord has a spectacular aura about
The most unique aspect of the robot that we currently have are two long arms, mounted to the chassis with bolts but capable of some back-and-forth movement due to surgical tubing. Once a tote is far enough into the robot, the arms naturally move in a bit to straighten the tote.
These arms can be made out of nearly anything, they're incredibly easy to install, and they are quite good at corralling totes. Because of their height, they don't interfere with the cooperation platform. They might also help remove a tote or two from the landfill zone.
If teams currently have no intake mechanism and want to quickly make a good one, I would strongly recommend using ours. (Just send all of those letters of praise and adoration to Team 3807.)
Here's a video.
We're also considering some other unique things to do... for the most part, though, we just need to refine the mechanisms that we already have.
Proudly getting injured by robots since 2013!
2013 - burned fingers on piece of hot metal, caught robot with leg when I tripped resulting in massive bruise
2014 - cut back of hand open with sharp piece of metal (I still have the scar), nearly electrocuted
2015 - Lost voice for two weeks following competition
2016 - Nothing yet!
Pink is a good color.
  #80   Spotlight this post!
Unread 12-02-2015, 17:49
IronicDeadBird's Avatar
IronicDeadBird IronicDeadBird is offline
Theory Crafting Fo days...
AKA: Charles Ives "M" Waldo IV
FRC #1339 (Angelbots)
Team Role: Tactician
IronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond repute
The strategy we are using isn't based around getting resources quickly. It is about doing it efficiently. 2 bins in 4 seconds is absolutely impressive and I look forward to seeing your robot perform. This year I tried to model game play strategy around a few games I found had similar constraints. What I ended up with in methodology isn't about doing things quickly its about spending time in ways where that get you the most out of the time.
My original plan was to tether to all the recycling bins on the field before auto and reeling them in. Then the GDC made the landfill a volume and only one container set scoreable rulewise. The other deal breaker on it was when I asked "what next?" On asking that question I found myself with a robot trapped in the auto zone by a bunch of recycling containers and taking up a significant chunk of space that could be detrimental to team scoring ability.
Securing resources is absolutely important in this years game.
But you still need to score those resources for it to matter.
HERO 俺を讃える声や 喝采なんて 欲しくはないさ
So I got my jacket back, but it turns out the "W" in WPI doesn't stand for that steak sauce I can't pronounce.
Play is for kids this is serious...
  #81   Spotlight this post!
Unread 12-02-2015, 20:21
mrnoble's Avatar
mrnoble mrnoble is offline
teacher/coach
FRC #1339 (Angelbotics)
mrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond repute
It reads to me that your team might have tried to move the totes from a different angle? I'd love to see a field drawing or strategy mat that showed how you were pushing. I don't get how moving the totes away from the step would lead to the scenario you describe.
  #82   Spotlight this post!
Unread 12-02-2015, 21:53
Daniel_LaFleur's Avatar
Daniel_LaFleur Daniel_LaFleur is online now
Mad Scientist
AKA: Me
FRC #2040 (DERT)
I think you maybe in for a surprise in this one I don't think the landfill is movable, good luck though
While not my teams strategy, I can easily see a flywheel design breaking up the landfill an allowing easy access to the step RCs during auto.
___________________
- Tennyson, Ulysses
  #83   Spotlight this post!
Unread 13-02-2015, 00:21
who716's Avatar
We think grabbing the high scoring field elements as soon as possible is the way to go not only does that save you time to use those field elements but it also Limits the opposing alliance...... I'll attempt to take pictures of our design tomarrow and post it, we added a wheely bar today because with both RC's 5 feet off the robot, frame the robot got alittle tipsy before we were able to bring them into the frame. the design is pretty much set in stone we just need a simple support to prevent the RC from rolling on the hooks.
Are you considering driving into the gap in the center and driving along the step pushing the totes towards your auto zone?
  #84   Spotlight this post!
Unread 13-02-2015, 00:51
mrnoble's Avatar
teacher/coach
Yes... But that doesn't seem like what you were describing earlier.
  #85   Spotlight this post!
Unread 13-02-2015, 09:40
Engineer at Medrobotics
AKA: Dr. Joe
FRC #0088 (TJ2)
Originally Posted by ArtemusMaximus View Post
"Scorpion" you say. Sounds like design I had in mind, but have no team this year to implement any of my ideas
I suspect scorpion part is the one that loads noodles into the can?
Pictures & videos soon, but your guess could not be further from the truth.
I can't swear we'll finish this beast on time our under weight but I will guarantee that if we manage to do so without having to jettison any major functionality or subsystem, we will have to explain the name to exactly zero folks who see this robot playing the game.
With that, I need to get back to work. One day of work left and then it's 100 or so of robots robots robots til Bag Time.
Dr. Joe J.
Team #88, TJ2
  #86   Spotlight this post!
Unread 13-02-2015, 09:49
346CADmen's Avatar
346CADmen 346CADmen is offline
FRC #0346
346CADmen is a splendid one to behold346CADmen is a splendid one to behold346CADmen is a splendid one to behold346CADmen is a splendid one to behold346CADmen is a splendid one to behold346CADmen is a splendid one to behold346CADmen is a splendid one to behold346CADmen is a splendid one to behold
Originally Posted by gpetilli View Post
Our team had a similar concept but ultimately realized it would be illegal since at least the cables for the trolley would be in the AUTO and/or Landfill zones at the start of the match.
Thought the same. But as a problem solver, considered adding swerve drive to each column. then expanding into those zones when appropriate.
  #87   Spotlight this post!
Unread 13-02-2015, 23:23
who716's Avatar
i wasn't i was thinking of something different, but i still have concerns. What exactly does this achieve for the allotted time used, okay you clear a path to the containers, which may or may not be useful to some teams. in lets say 10-15 seconds, then you end up with totes scattered and no longer packed which make it harder for passive design hooks to grab at, plus less maneuverability, it just seems much more complex strategy for less of a rewards.
  #88   Spotlight this post!
Unread 13-02-2015, 23:50
who716's Avatar
and as promised here is some pictures of our container design pretty much done, auto still needs fine programming but tel-op works so i don't see why auto wouldn't .
description, we have two arms double jointed and when fully extended are approx. 5 feet. each arm spins separately in a 360 degree rotation. using encoders to signify where they are. the arms are attached to a lift. that allows us to place the container on top of a 4 stack, since they spin we can be stacking totes on one end of the robot then place the RC can on top just by spinning the arms around. once the RC are captured, we fold our arms up to center the weight , and the RC's are then directly over the frame. this design allows us to pick up a can from anywhere on the field and from any position, and we can stack two at the same time as well. all together 4 seconds to grab two rc can off the step and pull them into the auto zone.
after our first trial we had to add a wheelie bar as when we first captured both RC the front end came up to high to the point were we could not drive now we drive a wheelie all the way into the auto zone then fold up.
ID:	18340  Click image for larger version
ID:	18341  Click image for larger version
ID:	18342  Click image for larger version
  #89   Spotlight this post!
Unread 13-02-2015, 23:54
who716's Avatar
one more.....
  #90   Spotlight this post!
Unread 14-02-2015, 00:48
PayneTrain's Avatar
PayneTrain PayneTrain is offline
no
AKA: Lizard King
FRC #0422 (The Meme Tech Pneumatic Devices)
Team Role: Mascot
PayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond repute
[IMG]
Dr. Joe J.
*looks at name of poster*
*looks at image*
I wouldn't expect any less than what I think you're doing
