Go to Post Such reasonableness will not be tolerated! This is teh interwebz! - pfreivald [more]
Unread 14-02-2015, 04:31
rame rame is offline
FRC #5615
Rookie Year: 2015
rame is an unknown quantity at this point
arcadeDrive, 3D Pro, pushing forward, goes backward
Hi,
I am a newbie and this my first post. Sorry.
We are using this Java code without making any changes.
https://wpilib.screenstepslive.com/s...p-test-program
myRobot.arcadeDrive(stick);
We are using the Logitech 3D Pro from the KOP.
The robot moves. But pulling backwards on the joystick = robot moves forwards. Pushing the joystick forwards = robot moves backwards.
How can we reverse this?
Sorry I do not know how to post code and I do not want to paste the code here.
Thanks in advance for your help.
Unread 14-02-2015, 07:36
Rakusan2 Rakusan2 is offline
AKA: Tomas Rakusan
FRC #3571 (Milton Mustangs)
Rakusan2 is an unknown quantity at this point
My suggestions is to take appart stick and use it as stick.getX () and stick.getY (). Also since you want to reverse forawd with backward, you can reverse the y value.
Therefore instead of myRobot.arcadeDrive (stick) put myRobot.arcadeDrive (-stick.getY(), stick.getX ())
Unread 14-02-2015, 09:13
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
Re: arcadeDrive, 3D Pro, pushing forward, goes backward
Check that you have the left and right motors connected to the correct ports as written into your code. Reversing left and right motors rotates the robot so that front is back and back is front.
Unread 14-02-2015, 16:47
FRC #5615
Rookie Year: 2015
Thanks, I will try this and report back. Much appreciated.
Unread 14-02-2015, 18:06
FRC #5615
Rookie Year: 2015
Thanks! That worked!!! Reversing the x and y value did the trick. Thanks!
