Go to Post This just goes to prove there was life before FIRST (but it wasn't as much fun!) - Ken Loyd [more]
Unread 14-02-2015, 10:15
wildaburk3160 wildaburk3160 is offline
FRC #3160
wildaburk3160 is an unknown quantity at this point
Re: Rotating with crab drive
I had actually thought about this before, but wasn't completely sure it would work.
Okay, that's what we will try to do. It shouldn't be too difficult.
Unread 14-02-2015, 10:20
If you tell me the length of your trackwidth and wheelbase, I can give you the exact angle you should use for completely scrubless/skipless turning.
trackwidth is the distance between the front (or rear) wheels.
wheelbase is the distance between the front left and rear left wheels (or front right and rear right wheels).
Unread 14-02-2015, 10:23
... and if you want the center of rotation to be something else than the center of the wheel pattern (like maybe closer to the front of the robot), let me know where and I'll tell you the wheel angles (and speeds) for that.
Unread 14-02-2015, 11:09
FRC #3160
Wheelbase: 11.717 in
Trackwidth: 26.626 in
Unread 14-02-2015, 11:30
Are you sure it isn't the other way around? What you've described is what is commonly called a "wide" robot (trackwidth greater than wheelbase).
trackwidth > wheelbase (wide robot):
      front
      back
trackwidth < wheelbase (narrow robot):
front
back
Unread 14-02-2015, 11:37
FRC #3160
Yes, I messed up the calculations there. Here is the cad drawing showing the distances from the centers of the wheels.
http://i.imgur.com/810iW19.png
The center of our wheelbase is not at the center of the frame, so the distance between the center of the frame and the center of the wheelbase is given.
Unread 14-02-2015, 11:40
The wheel pattern is very close to square. Use 45 degrees as mentioned previously.
Unread 14-02-2015, 11:43
FRC #3160
Will do.
Unread 14-02-2015, 14:04
FRC #3160
We got it working. Thanks for the input.
