Go to Post Woah woah, what about fingers? The programmers have to use something to type with? - dellagd [more]
Unread 14-02-2015, 11:42
urg8rb8 urg8rb8 is offline
FRC #0108
urg8rb8 is an unknown quantity at this point
Pressure Gauge Jumping/Bouncing around
We seem to be having a problem with our pressure gauge. When the compressor is filling up the air tanks, the pressure gauge bounces back and forth as the psi increases.
We have replaced the compressor, the pressure gauge and the tubes; however, the problem remains the same. Has anyone had/has this problem or knows whats wrong?
Unread 14-02-2015, 11:46
Chris_Ely's Avatar
Chris_Ely Chris_Ely is offline
AKA: luckof13
FRC #3414 (HackBots)
Chris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond repute
Re: Pressure Gauge Jumping/Bouncing around
How close is the gauge to the compressor?
If it is close to it, it will read varying pressure when the compressor is on. This is an artifact of how the compressor works. To fix this, just move the gauge farther away from the compressor. You may want to do the same with the pressure switch.
2013: Waterford Finalist, Livonia Winner, MSC Quarterfinalist, Curie Division
2012: Waterford, Northville, Livonia
2011: Waterford Finalist, Livonia
2010: Ann Arbor Rookie Inspiration Award, Troy
Mechanical Engineering Student,
Michigan Technological University
Unread 14-02-2015, 12:22
Mr V's Avatar
Mr V Mr V is offline
FRC #5588 (Reign)
That is normal, no need to worry or do anything about it.
Unread 14-02-2015, 12:23
rich2202 rich2202 is offline
FRC #2202 (BEAST Robotics)
That's why I have my team place the gauge/switch after the air tank (air physically passes through the air tank). The air tank acts like a damper, and smooths out the pressure.
Unread 14-02-2015, 12:37
Without knowing the location of your gauge and a video of what the gauge is doing, it would be hasty to say it is normal.
Unread 15-02-2015, 11:09
FRC #0108
Thanks everyone for the feed back! We moved the gauge further away from the compressor and the problem went away!
Unread 15-02-2015, 11:32
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
I'll take my time, but I'll also say it's normal. Without the benefit of video or further description.
Unread 15-02-2015, 12:36
With the benefit of the OP's recent post, it's no longer hasty:
