Go to Post But before we jump to conclusions, I'll wait for kickoff and the manual. ;) - BrendanB [more]
Unread 14-02-2015, 12:46
Hsifeulbhsifder Hsifeulbhsifder is offline
Programmer
AKA: Zaeem Mohamed
FRC #5428 (Breaking Bots)
Rookie Year: 2015
Hsifeulbhsifder is on a distinguished road
Problem uploading code to roboRIO on new laptop
I have been trying to switch from a previous laptop too a new laptop, and everything is just fine, when it comes to controlling the robot, but when it comes to uploading new code, i get this error message:
Buildfile: C:\Users\Jai P\Documents\Programs\workspace\2015_Prototype-1\build.xml
Trying to override old definition of task classloader
clean:
   [delete] Deleting directory C:\Users\Jai P\Documents\Programs\workspace\2015_Prototype-1\build
   [delete] Deleting directory C:\Users\Jai P\Documents\Programs\workspace\2015_Prototype-1\dist
compile:
    [mkdir] Created dir: C:\Users\Jai P\Documents\Programs\workspace\2015_Prototype-1\build
     [echo] [athena-compile] Compiling src with classpath=C:\Users\Jai P/wpilib/java/current/lib/WPILib.jar:C:\Users\Jai P/wpilib/java/current/lib/NetworkTables.jar to build
    [javac] Compiling 31 source files to C:\Users\Jai P\Documents\Programs\workspace\2015_Prototype-1\build
jar:
     [echo] [athena-jar] Making jar dist/FRCUserProgram.jar.
    [mkdir] Created dir: C:\Users\Jai P\Documents\Programs\workspace\2015_Prototype-1\dist
    [mkdir] Created dir: C:\Users\Jai P\Documents\Programs\workspace\2015_Prototype-1\build\jars
     [echo] [athena-jar] Copying jars from C:\Users\Jai P/wpilib/java/current/lib/WPILib.jar:C:\Users\Jai P/wpilib/java/current/lib/NetworkTables.jar to build/jars.
     [copy] Copying 2 files to C:\Users\Jai P\Documents\Programs\workspace\2015_Prototype-1\build\jars
      [jar] Building jar: C:\Users\Jai P\Documents\Programs\workspace\2015_Prototype-1\dist\FRCUserProgram.jar
get-target-ip:
     [echo] Trying Target: roboRIO-5428.local
     [echo] roboRIO found via mDNS
dependencies:
     [echo] roboRIO image version validated
     [echo] Checking for JRE. If this fails install the JRE using these instructions: https://wpilib.screenstepslive.com/s/4485/m/13503/l/288822-installing-java-8-on-the-roborio-using-the-frc-roborio-java-installer-java-only
  [sshexec] Connecting to roboRIO-5428.local:22
  [sshexec] cmd : test -d /usr/local/frc/JRE
deploy:
     [echo] [athena-deploy] Copying code over.
      [scp] Connecting to roboRIO-5428.local:22
      [scp] done.
  [sshexec] Caught exception: SSH_MSG_DISCONNECT: 2 Too many authentication failures for admin
BUILD FAILED
C:\Users\Jai P\wpilib\java\current\ant\build.xml:114: com.jcraft.jsch.JSchException: SSH_MSG_DISCONNECT: 2 Too many authentication failures for admin
Total time: 11 seconds
And the new code isnt uploaded, while the old code stays on the roborio, and still active.
Unread 14-02-2015, 19:25
Re: Problem uploading code to roboRIO on new laptop
Did you change the admin password on the roboRIO?
Unread 16-02-2015, 12:17
JacobD's Avatar
JacobD JacobD is offline
AKA: Jacob
FRC #1672 (Mahwah Robo T-Birds)
JacobD is an unknown quantity at this point
Someone else was having a similar problem. They edited their admin information. So, you have to change that in build.properties file within the USER/wpilib/java/current/ant directory.
Inside the build.properties file there us a username and password entry.
By default (I assume) the username is lvuser, with a blank password.
Then change the information to the correct username and password.
