Go to Post Trapping JVN (or any other IFI employee) is negative infinity [I]and[/I] a caption contest. Trapping 1114 is a measly 50 points, unless you trap Karthik, which multiplies your entire score by -1. - EricH [more]
Unread 14-02-2015, 15:25
connor_shaffer connor_shaffer is offline
FRC #2849 (Ursa Major)
connor_shaffer is an unknown quantity at this point
OpenCV Troubles
I am currently working on vision tracking for my team, and while I have been very successful, I ran into a recent roadblock. Unfortunately, when writing files to the roborio to view them, I have had the following images show up, and they appear to be a combination of the images I have used across the various stages in my vision program. Does anyone know how I could fix this? And fyi, it isn't consistent in whether or not it will have interference.
ID:	18350  Click image for larger version
Unread 16-02-2015, 11:27
Re: OpenCV Troubles
So I found a solution in case anyone else runs into this problem, I had to initialize my Mat in such a way as to set the starting value of each pixel, using the constructor Mat(int rows, int cols, int type, Scalar newVal)
