Go to Post The function of that part is to keep one student occupied playing with it during the entire build season. It doesn't have to be the same student all the time, they can take turns. - MrForbes [more]
Unread 14-02-2015, 15:48
zDrakon zDrakon is offline
FRC #3501
zDrakon is an unknown quantity at this point
ODROID Operating System outdated
Has anyone found a way to get a working eclipse on ODROID. The version of the operating system we have is outdated therefore does not have the necessary packages to install eclipse-pde apparently. It is too outdated to retrieve dependencies for eclipse packages.
Any links out there that give the most updated OS for ODROID U3? I tried hardkernel.com and the odroid "official" websites. Their links are outdated apparently. Thanks please help =D!
Unread 15-02-2015, 01:09
Fauge7 Fauge7 is offline
Head programmer
FRC #3019 (firebird robotics)
Fauge7 is a name known to allFauge7 is a name known to allFauge7 is a name known to allFauge7 is a name known to allFauge7 is a name known to allFauge7 is a name known to all
Re: ODROID Operating System outdated
Trust me when I say this, if your using a vision system with odroid and opencv, don't use java...already tried that not fun to get working...I could not get it working but python works fine! And so does c++...if you know java well enough to do vision processing on an odroid, you can learn python and use that
