Go to Post How are you supposed to conceptualize without a complete grasp of what your trying to do? - Aren_Hill [more]
Unread 09-02-2015, 12:36
WillNess's Avatar
WillNess WillNess is offline
Programmer
AKA: Will Ness
FRC #4944 (The Hi Fives)
WillNess is just really niceWillNess is just really niceWillNess is just really niceWillNess is just really nice
Re: Vision Tracking Solution
My laptop has OpenCV 2.4.10, and when we tried to upload code that had OpenCV in it, errors started with the imports, and then every time any part of OpenCV was located it was an error.
Outreach Lead // Lead Programmer // Junior
2014 FRC:
Rookie Allstar, Highest Rookie Seed & Semifinalist @ Utah
Rookie Allstar, Highest Rookie Seed & Semifinalist @ Colorado
2015 FRC:
Creativity In Engineering & Semifinalist @ Arizona West
Unread 09-02-2015, 13:33
Fauge7 Fauge7 is offline
Head programmer
FRC #3019 (firebird robotics)
Fauge7 is a name known to allFauge7 is a name known to allFauge7 is a name known to allFauge7 is a name known to allFauge7 is a name known to allFauge7 is a name known to all
try adding the opencv library to the build path of the project in eclipse
right click the project>java build path>Libraries>add external jar> find the java library installed should be in /path/to/opencv/build/java/opencv-2410.jar
Unread 09-02-2015, 13:42
WillNess's Avatar
Programmer
AKA: Will Ness
2014 FRC:
2015 FRC:
Unread 09-02-2015, 13:44
Head programmer
its meant to be run on the driverstation computer not the robotcode.
Unread 09-02-2015, 14:12
WillNess's Avatar
Programmer
AKA: Will Ness
Well I can't run the robot from the driver station computer with the code that has OpenCV when I can't upload code to the robo-rio. I get a build failed every time I try to upload the code.
2014 FRC:
2015 FRC:
Unread 10-02-2015, 17:32
WillNess's Avatar
Programmer
AKA: Will Ness
Wait, so should the opencv jar be in the JRE System Library thing, not on it's own separate library?
2014 FRC:
2015 FRC:
Unread 11-02-2015, 08:21
Head programmer
You set it up right, can you post your error? Or a link to your github
Unread 11-02-2015, 09:59
WillNess's Avatar
Programmer
AKA: Will Ness
Ya. I'm at school right now but when I get to robotics tonight I will upload my project & post my build path& errors.
2014 FRC:
2015 FRC:
Unread 14-02-2015, 15:49
WillNess's Avatar
Programmer
AKA: Will Ness
I cannot figure out how to upload to GitHub but if you give me your gmail I will share a google doc of it.
2014 FRC:
2015 FRC:
