Go to Post Build a GREAT robot (just not as good as mine). - Steve W [more]
Unread 13-02-2015, 21:12
JacobD's Avatar
JacobD JacobD is offline
AKA: Jacob
FRC #1672 (Mahwah Robo T-Birds)
JacobD is an unknown quantity at this point
RoboRIO does not store code
Hello Everyone,
I was reading in the control system manual and I noticed that the roboRIO is supposed to store code without needing a restart. But, when I deploy code over USB in eclipse, I have to restart the robot. If I do not, the code will disappear when I unplug the USB.
But, after toggling the power on the robot, the code stays.
Here is the link to the manual page on this: https://wpilib.screenstepslive.com/s...o#!prettyPhoto
Unread 13-02-2015, 22:03
Fauge7 Fauge7 is offline
Head programmer
FRC #3019 (firebird robotics)
Fauge7 is a name known to allFauge7 is a name known to allFauge7 is a name known to allFauge7 is a name known to allFauge7 is a name known to allFauge7 is a name known to all
Re: RoboRIO does not store code
configure the dlink so you can connect wirelessly, then you can upload code wirelessly
Unread 15-02-2015, 00:22
JacobD's Avatar
AKA: Jacob
I can do that already but this doesn't fix my problem.
Unread 15-02-2015, 01:44
Head programmer
Sounds like your code is crashing check the logs or upload the code on github for people to see
Unread 15-02-2015, 10:02
JacobD's Avatar
AKA: Jacob
The code is not crashing. I said that the code will only store if I turn the robot off. Otherwise, the code will disappear when I remove the USB. If I go through the process of power cycling the robot, then the code stays, and works as it should.
