Go to Post You don't have to beat stronger teams to get better... to get better is to be forced to push the envelope against stronger teams. - Shankar M [more]
Unread 08-03-2003, 23:00
Aaron Lussier's Avatar
Aaron Lussier Aaron Lussier is offline
Volunteer for hire
Aaron Lussier is a splendid one to beholdAaron Lussier is a splendid one to beholdAaron Lussier is a splendid one to beholdAaron Lussier is a splendid one to beholdAaron Lussier is a splendid one to beholdAaron Lussier is a splendid one to beholdAaron Lussier is a splendid one to behold
Originally posted by sanddrag
This is probably a stupid question but did you charge it after you took it out of the crate? They can discharge some after sitting for a while.
Yes Yes we did, we put them right on the charger, right out of the crate
Originally posted by sevisehda
Your bot has sat idle for a while, if your using the drill transmissions they won't be as loose as they were near the end of building. Its always good to warm up your bot in the pits on Thursday. Run the drive wheels, cylinders, arms and anything else you have. Remember lubracants settle and congeal you've got to spread them around.
You can easily check the voltage on the batteries. Also charge and replace them between every match.
We do not use Drill transmissions, we use the Atwood motors for drive, We had been checking voltage every match, but that was our problem we think the battery had been giving us a false charge, of like 13.2 so we were like" lets get this one becasue it will make us run the best, We later tested the battery in the bot with the bot off and we watched the numbers go:
13.2
13.1
13.0
12.9
12.8
All in the space of about thirty seconds, we had checked everything else on the bot and could not figure out what was wrong with it, eventually we worked are way back to the battery and found that out, but it was fri night when we found out... and even today we didnt do so hot, ohh well there always Nats...
Team 151 Student/Mentor 2001-2004
US Navy 2005 -2009
Volunteer 2010 - ???
Field Reset Extraordinaire
power to the pits Ken Leung Off-Season Events 12 11-05-2003 22:48
URGENT!! Need OI power brick specs for 7AM demo tomorrow!!! kmcclary Electrical 8 10-10-2002 10:56
power supply of control system archiver 2000 5 24-06-2002 00:14
power of globe motor with gear box? Ken Leung Motors 5 21-11-2001 13:43
Max mechanical power of motors, how is it useful? Ken Leung Motors 1 09-11-2001 14:15
