Go to Post We build because we can. - Danaca [more]
Unread 14-02-2015, 20:19
Dominick Ferone's Avatar
Dominick Ferone Dominick Ferone is offline
FRC #5030 (The Second Mouse)
Dominick Ferone is just really niceDominick Ferone is just really niceDominick Ferone is just really niceDominick Ferone is just really nice
Lead Screws Spinning Out Of Sync
We have two lead screws we are driving and one has been driving a little higher each time. It has the whole mechanism drive out of sync which could end up damaging the lead screws. Any ideas on how to fix this?
2010-2013 Team 353 The POBots - Student, 2014-present Alumni.
2014- present Team 5030 The Second Mouse - Mentor and Founder.
Unread 14-02-2015, 20:46
the_godfaubel's Avatar
the_godfaubel the_godfaubel is offline
College Mentor
AKA: Aaron Faubel
FRC #1208 (Metool Brigade)
the_godfaubel is a splendid one to beholdthe_godfaubel is a splendid one to beholdthe_godfaubel is a splendid one to beholdthe_godfaubel is a splendid one to beholdthe_godfaubel is a splendid one to beholdthe_godfaubel is a splendid one to behold
Re: Lead Screws Spinning Out Of Sync
You could sync them up with a chain. This would force the one that was lagging behind to speed up. Our team had success with this on our 2013 bot.
Unread 14-02-2015, 20:52
Chris_Ely's Avatar
Chris_Ely Chris_Ely is offline
AKA: luckof13
FRC #3414 (HackBots)
Chris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond repute
Are your motor controllers calibrated?
2013: Waterford Finalist, Livonia Winner, MSC Quarterfinalist, Curie Division
2012: Waterford, Northville, Livonia
2011: Waterford Finalist, Livonia
2010: Ann Arbor Rookie Inspiration Award, Troy
Mechanical Engineering Student,
Michigan Technological University
Unread 14-02-2015, 22:01
Joey1939's Avatar
Joey1939 Joey1939 is offline
AKA: Joey Holliday
FRC #1939 (Kuhnigits)
Joey1939 has a spectacular aura aboutJoey1939 has a spectacular aura aboutJoey1939 has a spectacular aura about
I totally agree on calibrating your speed controllers, but if you had to you could use a PID loop to make them both spin at the same speed. I know Talon SRXs have a built in mode for making them spin a specific speed based off a sensor input.
Unread 15-02-2015, 00:44
wilderbuchanan wilderbuchanan is offline
FRC #3408 (Killobyte Cubs)
Team Role: CAD
wilderbuchanan is an unknown quantity at this point
Make sure that the gear ratios are the same. My team had a similar problem and this was one of the answers. Also make sure the are in line.
Unread 15-02-2015, 01:26
catacon catacon is offline
FRC #1444 (Lightning Lancers)
catacon is a splendid one to beholdcatacon is a splendid one to beholdcatacon is a splendid one to beholdcatacon is a splendid one to beholdcatacon is a splendid one to beholdcatacon is a splendid one to beholdcatacon is a splendid one to behold
Calibrating the speed controllers is a good start. You can use an encoder to get the speed of each and tune a PID controller to run them both at the same speed. If you are using Talon SRXs, you can run one Talon as a follower so it will take the same input as another. This may be useful if you can only encode one lead screw. However, if the drives are (significantly) mechanically different, this will not solve you problem.
The "easiest" way around this, is to mechanically couple them. We have two ball screws this year: one on each side of the robot. We have a drive shaft running across the robot that couples them together. We are only encoding one ball screw and running two Talon SRXs in a leader-follower system.
Unread 15-02-2015, 01:34
Oblarg Oblarg is offline
AKA: Eli Barnett
The proper solution is to mechanically link the two drives.
Failing that, PID position control will probably work.
Simply calibrating the motor controllers will probably make it better, but will not fully solve the problem - motors and assemblies are non-identical and small differences in motor output and friction can contribute to significant differences in behavior.
"The breakfast of champions!"
Unread 15-02-2015, 01:51
theawesome1730's Avatar
theawesome1730 theawesome1730 is offline
FRC #1730 (Team Driven)
theawesome1730 will become famous soon enough
We have 2 ball screws this season that have to be timed and we had debated using PID loops, but ended up settling on mechanically timing due to its simpler nature and proven reliability. For example, timing belts (what we used) and chain are both methods of mechanically timing, you could use gears as well although it is trickier.
2015 GKC Engineering Inspiration
2015 Colorado Winners
