Go to Post If we can figure out how to make a robot in six weeks, a little thing like personality conflict should be easy to overcome. - Al Skierkiewicz [more]
Unread 14-02-2015, 17:10
BananaKing1378's Avatar
BananaKing1378 BananaKing1378 is offline
BaNaNaK1Ng8o8
AKA: Banene
FRC #1378 (Hilo Banana Robotics)
Team Role: Human Player
BananaKing1378 is an unknown quantity at this point
R.I.P VRM
We were testing robot, and all of a sudden, the VRM disconnected and shut off. When we touched the top of the VRM, it was hot. Now, the lights on the VRM do not turn on or work. We measured the power going to the VRM and it's measuring approx. 12 V.
We aren't sure what we can do except purchase a new VRM. Any tips on troubleshooting?
Unread 14-02-2015, 17:12
orangemoore orangemoore is offline
AKA: Roger Moore
FRC #3135 (Robotic Colonels)
orangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond repute
Re: R.I.P VRM
What is connected to your VRM?
Stronghold
Student 2013-2016
3135 -- Robotic Colonels
3507 -- Robotheosis (FTC)
matthewdenny's Avatar
matthewdenny matthewdenny is offline
FRC #6054 (Dukes)
matthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant future
Re: R.I.P VRM
What was connected to it? Specifically what things were drawing current, and how much?
Unread 14-02-2015, 17:16
BaNaNaK1Ng8o8
AKA: Banene
Re: R.I.P VRM
We only have the radio and some LED lights connected to it.
Unread 14-02-2015, 17:26
FRC #6054 (Dukes)
What's the current rating on the LEDs
Unread 14-02-2015, 17:50
wilful's Avatar
wilful wilful is offline
766 Alum & 4212 Mentor
FRC #4212 (TechnoFerrets)
wilful will become famous soon enough
Re: R.I.P VRM
From what I understand, the VRM has a peak current rating of 2 amps and a continuous load of 1.5 amps, and the radio has a 1.5 amp draw. Bit of a design oversight in my opinion, because if your robot has any other electronics that need a regulated voltage, you need another module.
For LED ring lights, I suggest you run them straight off the PDP, unless they aren't rated for 12 volts.
http://content.vexrobotics.com/vexpr...e-20141230.pdf
look at the bottom of page 7
Wilful
2009-2013 Student, FRC 766
2013-Present College Student and Mentor, FRC 4212
Unread 14-02-2015, 18:04
Re: R.I.P VRM
Originally Posted by wilful View Post
From what I understand, the VRM has a peak current rating of 2 amps and a continuous load of 1.5 amps, and the radio has a 1.5 amp peak draw.
Fixed that for you. The radio draws closer to half that continuous.
Unread 14-02-2015, 18:12
Re: R.I.P VRM
Maybe this could be a teaching moment...
Unread 14-02-2015, 23:44
Nickoris Nickoris is offline
AKA: Nick Rosato
FRC #5543 (MINTTZ)
Team Role: Student
Nickoris is an unknown quantity at this point
Re: R.I.P VRM
Our team did the same thing and now it is a paper weight. Why would they release this product with this big of a flaw?
Our team is debating getting a new one, or wait for a fixed version to be released. Since we have till week 4 for our first comp.
It is sad to know that this is going to be a common occurrence this year.
Unread 14-02-2015, 23:48
Anupam Goli's Avatar
Anupam Goli Anupam Goli is offline
PCH Q&A co-founder/Scouting Mentor
AKA: noops
FRC #1648 (G3 Robotics)
Anupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond repute
Re: R.I.P VRM
I mean in general you should never really have LED lights hooked straight to a power source without a resistor between them.
If you guys want to drive LED's, use the GPIO ports or a spike to drive them, don't hook them up straight to power....
Team 1002: 2008-2012
Team 1648: 2012-2016
Georgia Tech Class of 2016
Unread 15-02-2015, 06:25
rich2202 rich2202 is offline
FRC #2202 (BEAST Robotics)
Re: R.I.P VRM
The LED's we have are rated for 12 volts, so go on that port of the VRM. Use resistors, and/or hook them up in series to drop the voltage if you have 5v LED's. Or, make sure you don't overwhelm the 5V 500ma socket.
IMHO, other than the radio, don't put anything else on the 5V 2A socket of the VRM.
I wouldn't wait. The VRM is a mandatory item to power the Radio, and I doubt they can get "fix" out for this season. If you wait, and Andymark runs out, you are toast.
Unread 15-02-2015, 07:46
Michael Hill's Avatar
Re: R.I.P VRM
They still need current limiting resistors regardless of their voltage rating.
Unread 15-02-2015, 09:08
philso philso is offline
FRC #2587
Re: R.I.P VRM
If your LED's are "rated for 12V" or "rated for 5V" they probably already have the proper current limiting resistors (or some other current limiting device) integrated into them. If you are connecting a 5V rated LED string to 12V, you will have to first find out how much current the the LED's draw, then calculate the series resistance value needed to drop the voltage across the LED from 12V to 5V.
There should be no need to connect the LED's to the VRM. The Voltage Regulator Module is for powering devices that are critical to the proper functioning of your robot and are sensitive to voltage fluctuations, like your radio. Your LED's are not a critical function of your robot (though some of the students on our team would debate me on this issue) and short voltage fluctuations will probably not make a noticeable difference in how they operate.
