Go to Post I hope that all of our new members are as helpful as the one above. We will be in for an amazing season if that is the case. - Greg Needel [more]
Unread 14-02-2015, 21:05
popnbrown's Avatar
popnbrown popnbrown is offline
FIRST 5125 HOTH Lead Mentor
AKA: Sravan S
FRC #5125 (Hawks on the Horizon)
popnbrown has a reputation beyond reputepopnbrown has a reputation beyond reputepopnbrown has a reputation beyond reputepopnbrown has a reputation beyond reputepopnbrown has a reputation beyond reputepopnbrown has a reputation beyond reputepopnbrown has a reputation beyond reputepopnbrown has a reputation beyond reputepopnbrown has a reputation beyond reputepopnbrown has a reputation beyond reputepopnbrown has a reputation beyond repute
Solenoid LEDs not on / VEX Base Leak
We're having trouble getting the solenoids to work. The compressor works fine and is running, but the solenoids are not lighting up nor working.
I think the solenoids are wiring up fine, and we seem to have lost our multimeter....so I can't tell if there's any voltage going.
We're using the VEX Solenoid Base Mount - http://www.vexrobotics.com/solenoids-and-manifolds.html, and this also seems to be leaking. I presume it's because the solenoids are not getting power and are not blocking out the air.
I would love to show you wiring, but it's incredibly messy that even I have trouble following it sometimes. The connections were initially not weak, the solenoid wires popped out at a slight tug but we re-secured them.
Firmware for the PCM is at 1.62, it's reading no faults, and showing all the Solenoids as off.
I'm attaching our Begin.vi and our Teleop.vi.
ID:	18359  Click image for larger version
I am an employee of FIRST. However, the postings on this site are of my own perspective as a FIRST mentor and volunteer and do not necessarily reflect the views of FIRST.
FIRST Team 5125 Hawks on the Horizon Lead Mentor
FRC Team 4096 Ctrl-Z Former Mentor
FTC Team 5203 #19@! Former Mentor
FRC Team 1403 Cougar Robotics Alumni
Unread 14-02-2015, 21:19
Chris_Ely's Avatar
Chris_Ely Chris_Ely is online now
AKA: luckof13
FRC #3414 (HackBots)
Chris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond repute
Re: Solenoid LEDs not on / VEX Base Leak
If your manifold is leaking, you have a plumbing problem. How do you have it plumbed? Pressure should go into the port labeled P, and your cylinders should be connected to ports A and B. EA and EB are the exhaust, so leave these open. Does every fitting have Teflon tape, and are they tight? Put soapy water on the fittings, and look for bubbles to find out where the leaks are.
Try to clean up your wiring; diagnosing spaghetti at a competition is not fun, trust me.
Are you using single or double solenoids?
Unfortunately, it is difficult to diagnose problems we can't see. Can you post pictures, even if things are messy?
2013: Waterford Finalist, Livonia Winner, MSC Quarterfinalist, Curie Division
2012: Waterford, Northville, Livonia
2011: Waterford Finalist, Livonia
2010: Ann Arbor Rookie Inspiration Award, Troy
Mechanical Engineering Student,
Michigan Technological University
Unread 15-02-2015, 12:06
popnbrown's Avatar
AKA: Sravan S
Yeah, we got advice on this base from another thread. You can see the BaseTubing image, the first picture, attached below
All those that have threads have Teflon tape.
This is the current plan, I'll also double check the Teflon.
Fortunately, this is just our test platform. Unfortunately, it's not even fun diagnosing it right now. But the only way to learn is to do it wrong, and realize it's wrong. I hope there's at least one lesson learned about wiring here.
Single solenoids. SMC ones from VEX
I attached a close up of the PCM but it's not really helpfu this is the second picturel. The BaseWiring (third picture) is the better picture. You can actually attempt to follow the wires.
ID:	18370  Click image for larger version
ID:	18371  Click image for larger version
Last edited by popnbrown : 15-02-2015 at 12:08. Reason: pictures dont have names :(
Unread 15-02-2015, 12:12
orangemoore orangemoore is offline
AKA: Roger Moore
FRC #3135 (Robotic Colonels)
orangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond repute
Is your PCM jumper set to 12V or 24V?
Stronghold
Student 2013-2016
3135 -- Robotic Colonels
3507 -- Robotheosis (FTC)
Unread 15-02-2015, 12:14
Chris_Ely's Avatar
AKA: luckof13
It's a little hard to tell, but it looks like the voltage selection jumper is set to 24V. The solenoids from VEX are all 12V. Switching the jumper should fix the problem.
Unread 15-02-2015, 12:25
popnbrown's Avatar
AKA: Sravan S
I swapped it to 24V after posting this. It was originally 12V.
It was still not working when 12V.
Concur on the PCM 24v jumper. Those are 12v solenoids.
Are the LEDs for the individual solenoid 0 output on the PCM lighting up when button 5 is pressed?
Unread 15-02-2015, 13:39
AKA: Roger Moore
What is the CAN ID of your PCM? Does it match the one referenced in the code? I think it should be 0.
Stronghold
Student 2013-2016
Unread 15-02-2015, 14:02
popnbrown's Avatar
AKA: Sravan S
Well. that would be why. We were thinking they were supposed to light up indicating the Solenoid was being powered or it was initialized. I'll test out the buttons and see if that works.
Unread 15-02-2015, 14:03
popnbrown's Avatar
AKA: Sravan S
It's 0. We don't reference it in code. Using LabVIEW and I didn't think we had to reference it in code. Following the Solenoid example here - http://www.team358.org/files/program...view/index.php
I'm going to test pressing buttons and seeing it light up.
Unread 15-02-2015, 14:05
popnbrown's Avatar
AKA: Sravan S
General update, we're finding the solenoid base mount to be leaking quite a bit, from where the ports of the mount We unplugged the regulator and solenoid and just capped the other end, and it was finally starting to build some pressure. There was still some leaks, and it's because the Teflon on the threaded joints wasn't looking great and we didn't actually tighten them all the way.
Unread 15-02-2015, 14:09
popnbrown's Avatar
AKA: Sravan S
Solenoid lights are working when pressed. Thanks for the clarification Mark.
Now to fix the leak.
Unread 15-02-2015, 14:22
cglrcng cglrcng is offline
FRC #0060
cglrcng has a reputation beyond reputecglrcng has a reputation beyond reputecglrcng has a reputation beyond reputecglrcng has a reputation beyond reputecglrcng has a reputation beyond reputecglrcng has a reputation beyond reputecglrcng has a reputation beyond reputecglrcng has a reputation beyond reputecglrcng has a reputation beyond reputecglrcng has a reputation beyond reputecglrcng has a reputation beyond repute
Begin by removing all the black tubes 1-by-1 from the block and check for flush tube end cuts (square), tube ends, trim as necessary properly, and re-insert them, push all the way into the connector & pull or tug out to make sure they are fully seated properly...I can see the bottom second one in pic#3 is not all the way in, see how the connector is higher than all the rest nearby. *That should not stop the lights from working on the individual sol's, but minimum air pressure is needed to actually make them fire. No doubt in my mind that port is leaking much air.
Will the system currently hold stored air for say 15 or 30 minutes or more if you pump it up to 60~100PSI without leaking down much? If not, get that right first. Start at the compressor and find the leaks first, 1 connection at a time. Once it does, try overnight. Pump it up, turn off robot power, watch gauges for pressure bleed down.
I'm sure you already found that speed controller in the pics w/ only the ground attached and the positive not attached any longer upper left in pic #1.....Looks like it (the hot), is in your fingers. And need a bit more insulation tape on the PDB connectors main power connections (IMPORTANT not to see any of the silver connectors there). Also suggest blowing that bot out w/ some compressed air to clean out the debris a lil'.
Addition: I just looked at Pic#1 and the second black tube in the top row also isn't seated all the way in either.
Unread 15-02-2015, 14:42
FRC #0060
Also, if you have more tubing avail., I would replace both the inlet and outflow tubing to/from the regulator (and maybe even the connectors to straights from 90's maybe) w/ a little longer tubes as they are pulling the connectors off center which can also lead both (all 3~Reg. in/reg. out/ & block in connectors to leak.
That yellow locking collar on the regulator is half way up, half way down in the pic....Up to adjust regulator pressure, down to lock. Get it into 1 or the other positions also...right side is down/left up in the pic. When it is in the adjustment position it leaks very slightly on purpose to help you adjust the regulator pressure so after adjusting it, always lock it.
Can you attach a few more pictures?
Start at the compressor and work back to the block please. Getting the High Pressure side completed first and holding air (always insert a pressure relief valve in it), dividing the system into sections, and then working towards the low pressure section 2nd. seems to work best when making sure the system doesn't leak.
Unread 15-02-2015, 15:02
popnbrown's Avatar
AKA: Sravan S
Some more pictures. Sorry some of them are crappy quality. Let me know if there are close-ups of anything specific you'd like.
We've been re-doing some of the tubing because it got frustrating trying to debug things would get pulled out.
So we had a leak right out from the compressor, and then a leak near the release valve and the high pressure gauge. The air tanks all seem to be good even though the one T joint seems a little iffy.
We were able to get both the High Pressure side working, although I'd like to run a test to see how the pressure may bleed, so we'll do that.
We also just setup a low pressure side with the outlet of the regulator just sent to a release valve, and that also seemed to build pressure, although it was going to about 40 PSI, and would keep going while it was still at 40.
So with the solenoid base, the orange connectors on the base being close to each other means that it is fit better than when the orange connectors are farther apart?
ID:	18375  Click image for larger version
ID:	18376  Click image for larger version
ID:	18377  Click image for larger version
