Go to Post Hi. My name is Rick and I am a Roboholic. - Rick TYler [more]
Unread 15-02-2015, 10:27
jhersh jhersh is offline
National Instruments
AKA: Joe Hershberger
FRC #2468 (Appreciate)
Re: Correcting Mecanum Wheels with Encoders (Ether, We Summon You!)
Originally Posted by Alan Anderson View Post
How heavy is your robot, and how is the weight distributed? The symptom sounds like the back wheels are slipping a little on the carpet, which suggests that the robot is front-heavy.
Another thing to consider that strongly affects mecanum... is your frame square? Perhaps one of the wheels is off the ground or bears too little of the weight.
Unread 15-02-2015, 10:51
Toa Circuit's Avatar
Toa Circuit Toa Circuit is offline
Thaddeus Maximus
AKA: Thad Hughes
FRC #4213 (MetalCow Robotics)
Toa Circuit is an unknown quantity at this point
My #1 concern in your setup is this:
What is causing the odd strafing? If it's wheel slippage (my main guess), encoders on the drive wheels won't help you. Consider using a gyroscope to get your error. You'll likely be happier anyways.
2012 Head of Programming and Electrical
2013-14 Overall Team Captain and Programming Head
2012-14 Mentor of FLL Team Power Surge
2014 Dean's List Finalist
2014 CIR Xerox Creativity Award
Webpage
Unread 15-02-2015, 12:26
The OP has stopped responding to his thread, so we don't know the status is, or if he is still reading.
But so far, the responses have not addressed his original question:
Originally Posted by goldenguy00 View Post
To fix this, we are using encoders, but we are running into some severe difficulties my question is ... what am I doing wrong in the second example? The robot does not move in autonomous, nor in teleop.
Unread 15-02-2015, 12:42
Through a bit of troubleshooting, I found that this works...
public class TalonCan {
    CANTalon talon;
    public TalonCan(int canID){
	talon = new CANTalon(canID);
        talon.changeControlMode(ControlMode.PercentVbus);
And this doesn't...
    CANTalon talon;
	talon.changeControlMode(ControlMode.Speed);
	talon.setPID(0.1, 0.001, 1, 0.0001, 100, 36, 0);
	talon.set(0);
	talon.setFeedbackDevice(FeedbackDevice.QuadEncoder);
I believe it's from not using the encoders, so my question is, what am I doing wrong in the second example? The robot does not move in autonomous, nor in teleop.
I assume that since you are only showing the constructor that you are not changing anything else. That would be your problem I suspect. When you change modes, you change the units of "set();". That means you need to select a velocity based on your joystick. If you are using it like you should for a typical open-loop robot, then the values you are sending to set() are -1 to 1. This means that when you switch to closed loop you are asking for a velocity of -1 to 1. Depending on your sensor (you indicated an encoder) that is incredibly slow. Depending on how your PID constants are tuned, it may give the results you described.
Unread 15-02-2015, 13:37
Ken Streeter's Avatar
Ken Streeter Ken Streeter is online now
Let the MAYHEM begin!
FRC #1519 (Mechanical Mayhem)
Ken Streeter has a reputation beyond reputeKen Streeter has a reputation beyond reputeKen Streeter has a reputation beyond reputeKen Streeter has a reputation beyond reputeKen Streeter has a reputation beyond reputeKen Streeter has a reputation beyond reputeKen Streeter has a reputation beyond reputeKen Streeter has a reputation beyond reputeKen Streeter has a reputation beyond reputeKen Streeter has a reputation beyond reputeKen Streeter has a reputation beyond repute
Just to add a little bit more to what Joe has said, the "velocity" in the Talon SRX when using speed (velocity) control mode is in counts per 1/10 of a second. See section 17.1 of the Talon SRX Software Reference Manual for a little more info. On our robot, our top speed as measured on the Talon SRX is around 600 units, so we use set() commands which range from -600 to +600.
Ken Streeter - Team 1519 - Mechanical Mayhem (Milford Area Youth Homeschoolers Enriching Minds)
2015 NE District Winners with 195 & 2067, 125 & 1786, 230 & 4908, and 95 & 1307
2013 World Finalists & Archimedes Division Winners with 33 & 469
2013 & 2012 North Carolina Regional Winners with teams 435 & 4828 and 1311 & 2642
2011, 2010, 2006 Granite State Regional Winners with teams 175 & 176, 1073 & 1058, and 1276 & 133
Team 1519 Video Gallery - including Chairman's Video, and the infamous "Speed Racer!"
