Go to Post I'd just give you the URL, but then you wouldn't learn to look for yourself. - DonRotolo [more]
Unread 15-02-2015, 12:27
Potatoes's Avatar
Potatoes Potatoes is offline
AKA: Eric Wittmann
FRC #5136 (Mecha Pirates)
Potatoes is an unknown quantity at this point
Button 9?
We are using an Xbox 360 controller. We are trying to open a solenoid when the left stick is pressed down, close it when the right stick is pressed. The driver station reads Left Stick as button 8, Right Stick as button 9 (buttons start at 0). However, in LabView the joystick button unbundle only goes to button 8, as shown below. Expanding the bundle just shows me more "Button[8]"s, which all read the same value (Left Stick). My question is, how can I get it to read the Right Stick (button 9) input?
Unread 15-02-2015, 12:48
HostileGato HostileGato is offline
FRC #4005
HostileGato is an unknown quantity at this point
Re: Button 9?
I am a new programmer but I have think I have a solution to your problem. Replace the button cluster with an index array instead and label it with numeric constants you want such as nine. Team 358 has some great examples on what this would look like. http://www.team358.org/files/program...view/index.php
Unread 15-02-2015, 12:51
Re: Button 9?
Or right click on the node that converts from array to cluster, select the Cluster Size... item, and in the little dialog, enter 12, or however many buttons your controller has. Notice that it defaults to eight and was causing the limit of the buttons.
Index Array has no such limit since its size is determined at runtime and not compile time.
Greg McKaskle
Re: Button 9?
right-click on the Array To Cluster and choose Cluster Size to increase the number of buttons.
Unread 15-02-2015, 14:07
Potatoes's Avatar
AKA: Eric Wittmann
Re: Button 9?
It worked! Awesome, thank you!
