Go to Post Anyway, everyone, PLEASE READ THE MANUAL VERY CAREFULLY and ask around for the answers before going directly to FIRST. :) - AmyPrib [more]
Unread 14-02-2015, 19:36
thetimelord thetimelord is offline
None #2035
thetimelord is an unknown quantity at this point
Light Codes on Victors
Helllo I am a programmer for the team 2035, and I am having a problem with the Victor speed controllers. It seems that the LEDs on the victors only light up red or green on full speeds, is this true? Thanks.
Team 2035 Robo-Rockin' Bots
Unread 14-02-2015, 19:53
JohnSmooth42 JohnSmooth42 is offline
Is writing code
FRC #0375 (The Robotic Plague)
JohnSmooth42 is an unknown quantity at this point
Re: Light Codes on Victors
I know for the Talon SR's it works similarly, green and red being different directions. They also blink at a certain frequency based on the speed they're set to(at least the talons do).
Unread 14-02-2015, 20:10
AustinShalit's Avatar
AustinShalit AustinShalit is offline
AKA: אוסטין
no team (WPILib Suite Developer)
AustinShalit is a glorious beacon of lightAustinShalit is a glorious beacon of lightAustinShalit is a glorious beacon of lightAustinShalit is a glorious beacon of lightAustinShalit is a glorious beacon of lightAustinShalit is a glorious beacon of light
On the Victor 888 the light codes are:
• Green = Full Forward
• Orange = Neutral/Brake
• Red = Full Reverse
• Flashing Orange = no PWM
The Victor SP codes are:
• Solid Orange = PWM Signal is within 4% of Neutral
• Blinking Red = Reverse PWM Signal Applied - Blink speed is proportional to input
• Solid Red = Full Reverse PWM Signal is applied
• Blinking Green = Forward PWM Signal Applied - Blink speed is proportional to input
• Solid Green = Full Forward PWM Signal is applied
• Blinking Orange = No PWM Signal
• LEDs Alternate Red/Orange = Damaged Hardware
Unread 14-02-2015, 20:15
Mr V's Avatar
Mr V Mr V is offline
FRC #5588 (Reign)
Yes that is normal for them to only be solid red or greeen when they are commanded for 100% power. Less than 100% power and they will blink and that blink will be somewhat proportional to the commanded power.
Unread 15-02-2015, 13:36
Not true for all model Victors. See post#3.
Unread 15-02-2015, 13:43
mshafer1 mshafer1 is offline
Programming Mentor
AKA: Matthew Shafer
FRC #3937 (Breakaway)
mshafer1 is an unknown quantity at this point
I would also recommend that you keep in mind the fact that the human eye sees at approximately 80Hz, so if the pwm signal has a higher frequency, the LED will appear solid (in whichever color).
Unread 15-02-2015, 13:47
I could be wrong, but I would bet that the folks at VEX and CTRE who designed the circuit that blinks the indicator LEDs did so such that what appears solid to the human eye is truly 100%, and not 99%.
