Light Codes on Victors
Helllo I am a programmer for the team 2035, and I am having a problem with the Victor speed controllers. It seems that the LEDs on the victors only light up red or green on full speeds, is this true? Thanks.
Team 2035 Robo-Rockin' Bots |
Re: Light Codes on Victors
I know for the Talon SR's it works similarly, green and red being different directions. They also blink at a certain frequency based on the speed they're set to(at least the talons do).
On the Victor 888 the light codes are:
• Green = Full Forward • Orange = Neutral/Brake • Red = Full Reverse • Flashing Orange = no PWM The Victor SP codes are: • Solid Orange = PWM Signal is within 4% of Neutral • Blinking Red = Reverse PWM Signal Applied - Blink speed is proportional to input • Solid Red = Full Reverse PWM Signal is applied • Blinking Green = Forward PWM Signal Applied - Blink speed is proportional to input • Solid Green = Full Forward PWM Signal is applied • Blinking Orange = No PWM Signal • LEDs Alternate Red/Orange = Damaged Hardware |
Yes that is normal for them to only be solid red or greeen when they are commanded for 100% power. Less than 100% power and they will blink and that blink will be somewhat proportional to the commanded power.
I would also recommend that you keep in mind the fact that the human eye sees at approximately 80Hz, so if the pwm signal has a higher frequency, the LED will appear solid (in whichever color).
#7
