Go to Post Next year they should make Roombas the game piece. They're not very effective at vacuuming the rug that's for sure. - Koko Ed [more]
Unread 13-02-2015, 17:30
Re: Dry Ice as Motor Coolant
Originally Posted by techhelpbb View Post
Probably can't stop you from using fully melted dry ice in no container
Physics will stop you from storing "fully melted" (liquid) CO2 in no container.
Unread 13-02-2015, 22:44
techhelpbb's Avatar
FRC #0011 (MORT - Team 11)
Technicality
Unread 13-02-2015, 23:59
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
Originally Posted by G25
ROBOTS may not intentionally detach or leave parts on the FIELD.
As I recall, the field is a volume, not a surface, so venting carbon dioxide to the atmosphere would violate G25 as well.
Unread 14-02-2015, 01:14
seg9585's Avatar
seg9585 seg9585 is offline
AKA: Eric
FRC #4276 (Surf City Vikings)
seg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond repute
Hah. In that case, wouldn't an infinitesimal amount of pneumatics accumulator leakage also break the same rule? We will need to reference the Maxwell-Boltzmann distribution equations to know how quickly G25 becomes violated.
My FIRST legacy:
Team 204 Student 2001, 2002 (Voorhees, NJ)
Team 1493 College Mentor 2006 - 2008 (Troy, NY)
Team 2150 Intern/Professional Mentor 2007, 2009 (Palos Verdes)
Team 4123 Lead Engineering Mentor 2012 (Bellflower, CA)
Team 4276 Engineering Mentor 2012-2016 (Huntington Beach, CA)
Unread 14-02-2015, 01:56
BBray_T1296's Avatar
I am Dave! Yognaut
AKA: Brian Bray
Originally Posted by alicen View Post
It's dangerous, technically a hazardous material, and has potential for leakage or spilling, thus causing damage to the field or other robots.
I understand the whole argument that dry ice could be considered a hazard to humans, but out of curiosity I am interested in how you think any amount of dry ice (let's be reasonable) could cause damage to the field or other robots.
I feel like dumping air from the pneumatic system is more dangerous to a robot simply from the moisture condensate in the tanks
By the way, at any standard temperature for a robotics venue, dry ice does not melt, but sublimes
Unread 14-02-2015, 09:11
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
Poorly secured dry ice on a robot would be a hazard if the robot tipped. Plus you're going to confuse field staff with your "smoking" motor. Plus thermal stresses like that aren't good for a motor. Plus condensation. I'll pile on with everyone else and ask what you're doing to this motor that's making it so hot.
Unread 14-02-2015, 09:56
CO2 cannot exist as a liquid below 75 psi pressure, regardless of temperature.
Also, CO2 cannot exist as a true liquid above approx 31 degrees C, regardless of pressure.
Unread 15-02-2015, 13:36
josephus's Avatar
josephus josephus is offline
FRC #2980
josephus is an unknown quantity at this point
Additionally, if you start a match with five grams of a substance and you end the match with five grams less than you started with, are you leaving materials on the field?
Unread 15-02-2015, 13:50
...because CO2 is heavier than air?
Unread 15-02-2015, 14:06
matthewdenny's Avatar
matthewdenny matthewdenny is offline
FRC #6054 (Dukes)
matthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant future
I would think the "leaving it on the field" argument people are making here would apply to pre pressurized pneumatics as well? Technically your robot would have less mass if the pneumatics was lower pressure at the end.
Unread 15-02-2015, 16:07
who716's Avatar
who716 who716 is offline
AKA: Stephen Kalogiannis
FRC #0716 (Who'sCTEKS)
who716 is a splendid one to beholdwho716 is a splendid one to beholdwho716 is a splendid one to beholdwho716 is a splendid one to beholdwho716 is a splendid one to beholdwho716 is a splendid one to beholdwho716 is a splendid one to beholdwho716 is a splendid one to behold
we have specially made aluminum that we place on the motors in between matches and the heat from the motors transfers right over to heat the aluminum
-WPI number one seed
-Innovation in controls award
- NECMP#4 seed semifinalist
- 9th in NEW ENGLAND
2008- Connecticut regional winners
2004-UTC new England regional Winners
2001 highest rookie seed award winner
