Re: Talon Calibration
When you calibrate a talon, the talon finds the min and max signals and then makes that the min and max output. If you don't "hit" the max/min when calibrating, your talon could receive signal without it actually receiving signal, if that makes sense. So when you calibrate, I would move the joystick 360 degrees, just to make sure you hit your max and min
