Go to Post If you speak three languages, you're trilingual. If you speak two languages, you're bilingual. And if you speak one language, you're American. - Hieb [more]
Unread 15-02-2015, 13:57
VaneRaklan VaneRaklan is offline
FRC #2557 (The SOTABots)
VaneRaklan is an unknown quantity at this point
Talon Calibration
So for some reason when I try to go to calibrate one of my talons, it won't go into its calibration state. Any ideas why? (also i has a constant blinking yellow.)
Unread 15-02-2015, 13:59
Re: Talon Calibration
Talon SRX? If so it has an old firmware version, you should connect it to CAN (connecting it direct to the roboRIO as the only device, temporarily, works fine) and update the firmware, then you can put it back to PWM if you want.
Unread 15-02-2015, 14:01
Snowfire Snowfire is offline
Team 2410 Frame/Drivetrain Team
FRC #2410 (Metal Mustangs)
Snowfire is an unknown quantity at this point
When you calibrate a talon, the talon finds the min and max signals and then makes that the min and max output. If you don't "hit" the max/min when calibrating, your talon could receive signal without it actually receiving signal, if that makes sense. So when you calibrate, I would move the joystick 360 degrees, just to make sure you hit your max and min
Team 2410
Mechanical, Electrical, Pneumatic, and Drivetrain
Unread 15-02-2015, 14:09
Did you mean orange? The blinking orange on Talon SR means it's not getting a valid PWM signal.
What calibration procedure are you following?
Unread 15-02-2015, 15:17
Ky0t3's Avatar
Ky0t3 Ky0t3 is offline
AKA: Wiley Jordan
FRC #5178 (Nerdy Birds)
Team Role: Electrical
Ky0t3 is an unknown quantity at this point
Make sure the PWM cable is fully plugged in. We had the same problem, turns out the PWM cable just wasn't fully pushed into the controller.
