Go to Post Now, what we really need is a big spotlight in the sky that shoots out the letters "CD" so Brandon knows to come running to the server cave ... - mtrawls [more]
Thread Tools Rating: Thread Rating: 14 votes, 5.00 average. Display Modes
  #121   Spotlight this post!
Unread 13-02-2015, 11:01
FrankJ's Avatar
FrankJ FrankJ is offline
Robot Mentor
FRC #2974 (WALT)
Re: Al's Annual Inspection Thread 2015
While not formerly defined in the glossary. Bumpers are still an inspection check list item. Listed as optional. I understand why it is there since it is a considerable departure from previous years rules.
"Previous years rules do not apply to the current game." Now where have I heard that before?
  #122   Spotlight this post!
Unread 14-02-2015, 08:43
Originally Posted by FrankJ View Post
I understand.
From a functionality point of view he check valve needs to be attached directly to the compressor to keep the compression ratio as high as possible. The braided hose there to keep people from attaching plastic hose directly to the compressor which can be hot enough to cause the plastic hose to fail.
I checked on this when that compressor became an option a few years ago. The manufacturer requires it as it supplies a cooling path for the hot air. On that compressor only, as it is required by the manufacturer, the hose is considered part of the compressor and must be attached. As a note, I have only seen one in inspection.
  #123   Spotlight this post!
Unread 14-02-2015, 09:34
Toa Circuit's Avatar
Toa Circuit Toa Circuit is offline
Thaddeus Maximus
AKA: Thad Hughes
FRC #4213 (MetalCow Robotics)
Toa Circuit is an unknown quantity at this point
Are we permitted to put a two-way manually operated tee-valve between 60 a psi source and a solenoid valve, such that in one position, the valve connects 60 psi to the solenoid input (like if it were a normal connection), and in the other position, the valve connects atmosphere/vent to the solenoid input, and blocks off the 60 psi source? (We want to be able to move some pistons by hand during setup, but don't want to evacuate our air tanks to do this.)
2012 Head of Programming and Electrical
2013-14 Overall Team Captain and Programming Head
2012-14 Mentor of FLL Team Power Surge
2014 Dean's List Finalist
2014 CIR Xerox Creativity Award
Webpage
  #124   Spotlight this post!
Unread 14-02-2015, 14:15
Jon Stratis's Avatar
Mentor, LRI, MN RPC
FRC #2177 (The Robettes)
I can guarantee you'll see another one up in Duluth this year
2016: Lake Superior WFFA
  #125   Spotlight this post!
Unread 14-02-2015, 14:44
rich2202 rich2202 is offline
FRC #2202 (BEAST Robotics)
Would that be an R66F Flow control Valve?
Make sure that in either position, R78 requirement is met (vent the entire system), and
R79 (output of multiple valves) are not plumbed together (solenoid and manual valve).
  #126   Spotlight this post!
Unread 14-02-2015, 15:56
Thaddeus Maximus
AKA: Thad Hughes
It's essentially one of these, but plastic: http://www.valworx.com/product/bronz...8utBoCiA7w_wcB
So yes, R78 is met, as well as R79 (this is a series system, not a parallel system).
Webpage
  #127   Spotlight this post!
Unread 15-02-2015, 10:00
Thad,
From your description I would say the valve does not meet the intent of the rules. I would however recommend you ask the Q&A for a more definitive answer.
  #128   Spotlight this post!
Unread 15-02-2015, 10:16
While we are on the subject, the pneumatic rules haven't really changed much for many years, this year but there may be one or two gotchas...
1. Please understand the "one and only one" in R68. This means that only one compressor can supply air to the robot. If it fails you can replace it with a functional and identical one without the need to reinspect. If you have one mounted on your robot, you may not use another one to supply air for a match. That means you cannot have a compressor on your cart, in your pit or behind a curtain that you use to supply air to your robot. You may not run the compressor connected directly to a battery, ever.
2. The one compressor can be on board you robot or off board your robot. In all cases the one compressor must be controlled by the RoboRio sensing system pressure.
3. No white Clippard tanks.(P/N: AVT-PP-41)
4. The only pressure switch you may use is a Nason pressure switch, P/N SM-2B-115R/443 under R67-C. Often teams mount this near the outside of the robot, please be sure to insulate the terminals once you have connected your wiring.
5. There are several example drawings in the robot rules for your use.
6. Pneumatic parts may not be modified in any way other than the prescribed use and attachment of tubing adapters and mounting. Painting, filing, gluing, drilling, etc. are considered modifications.
7. If you are using pneumatic parts that are not normal devices, be sure to have manufacturers sheets detailing the max pressure ratings. Home made manifolds do not meet pneumatic rules under R64.
Hope you are getting close to finishing your robots. Bag day is just two days away.
  #129   Spotlight this post!
Unread 15-02-2015, 11:57
Jacob Bendicksen's Avatar
Jacob Bendicksen Jacob Bendicksen is offline
Figuring out what's next
Jacob Bendicksen has a reputation beyond reputeJacob Bendicksen has a reputation beyond reputeJacob Bendicksen has a reputation beyond reputeJacob Bendicksen has a reputation beyond reputeJacob Bendicksen has a reputation beyond reputeJacob Bendicksen has a reputation beyond reputeJacob Bendicksen has a reputation beyond reputeJacob Bendicksen has a reputation beyond reputeJacob Bendicksen has a reputation beyond reputeJacob Bendicksen has a reputation beyond reputeJacob Bendicksen has a reputation beyond repute
Someone asked this in the 148 reveal thread, and I'm curious, so I'm asking it here: how would a robot like 148's be inspected with regards to numbering? Seems like it's in a bit of a gray area.
jacobbendicksen.com | @jacobbendicksen
Yale University Class of 2020
Team 1540 | 2012-2016
7 Chairman's Awards, 6 other awards, 2015 Dean's List Finalist, 1 event win, 2 finalist finishes. Thanks for an amazing ride.
  #130   Spotlight this post!
Unread 15-02-2015, 12:48
Foster Foster is offline
Engineering Program Management
VRC #8081 (STEMRobotics)
Foster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond repute
There is another HUGE thread about numbers. Black numbers on a white background, etc. There are three parts to number, they number all three and they are done. I really don't get the mystery over the numbers, it's pretty plain and simple.
Foster - VEX Delaware - 17 teams -- Chief Roboteer STEMRobotics.org
2010 - Mentor of the Year - VEX Clean Sweep World Championship
2006-2016, a decade of doing VEX, time really flies while having fun
Downingtown Area Robotics Web site and VEXMen Team Site come see what we can do for you.
  #131   Spotlight this post!
Unread 15-02-2015, 14:49
My question was more about multi-part, tethered robots like 148. I get the regular numbering rules, but when a robot has multiple almost-separate components, it could be hard for viewers to tell that they're all part of the same machine.
  #132   Spotlight this post!
Unread 15-02-2015, 16:29
TogetherSword8 TogetherSword8 is offline
FRC #0888 (Robotiators)
TogetherSword8 is an unknown quantity at this point
I know your are an inspector and not a referee, but are we allowed to, during setup on the field, activate our pneumatics systems via pushing the buttons on the solenoids of our robot? I would like to start a match with our pneumatics systems out of the robot, but during transport, no pressure and with pressure, they would be fully contained within the transport configuration.
I program a robot. Which means I write code and everyone gets mad at me when something doesn't work, even if I am the only one that knows it doesn't work. The key part to know is that the robot never works.
  #133   Spotlight this post!
Unread 15-02-2015, 16:46
MrRoboSteve MrRoboSteve is offline
AKA: Steve Peterson
FRC #3081 (Kennedy RoboEagles)
MrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond repute
A good way to think about this is to find the rule that allows what you want, and think about how you might argue that what you want to do is permitted. If there's some ambiguity, use the Q&A system.
2016-17 events: 10000 Lakes Regional, Northern Lights Regional, FTC Burnsville Qualifying Tournament
2011 - present · FRC 3081 Kennedy RoboEagles mentor
2013 - present · event volunteer at 10000 Lakes Regional, Northern Lights Regional, North Star Regional, Lake Superior Regional, Minnesota State Tournament, PNW District 4 Glacier Peak, MN FTC, CMP
http://twitter.com/MrRoboSteve · www.linkedin.com/in/speterson
  #134   Spotlight this post!
Unread 15-02-2015, 18:07
In R65 (allowed changes to pnumatics), the blue box says: "Do not, for example, paint ... any part of a pneumatic".
I remember a discussion last year about no labels or writing on plastic air tanks. In theory, the ink or adhesive could weaken the tank wall.
However, R65-E allows labeling.
So, can people put stickers, or write, on the air tanks or hoses?
  #135   Spotlight this post!
Unread 15-02-2015, 18:13
At a Week 0 event this weekend, I noticed a lot of batteries that were not fully restrained. I mentioned it to the teams, and the typical response is: "Oh, we've driven it, and it doesn't move". At which point I show them the R22 that says the battery must be secured in any arbitrary orientation, including turning the robot upside down.
Teams: Fully secure your battery.
BTW: I also saw one team violate the frame perimeter of another team during autonomous. Robots still need to be protected.
