Go to Post Start simple and build up. - Mark McLeod [more]
Unread 15-02-2015, 16:27
Levansic's Avatar
Levansic Levansic is offline
AKA: Len Evansic
FRC #0585 (Cyber Penguins)
Levansic has much to be proud ofLevansic has much to be proud ofLevansic has much to be proud ofLevansic has much to be proud ofLevansic has much to be proud ofLevansic has much to be proud ofLevansic has much to be proud ofLevansic has much to be proud ofLevansic has much to be proud ofLevansic has much to be proud of
Re: Use a button to make a motor move a certain number of rotations
Your snippets are illuminating.
OK, here's the rest of the story. Unfortunately, you won't have a simple way of just sending a number to the motor controller, as you are using PWM Victors, which have no understanding of encoders or close loop modes.
You will need to implement a PID control in LabView, where the encoder inputs are compared to your desired position. The outputs will drive the motor voltages up and down, until the desired position is realized.
LabView has several built-in PID functions, and there are many threads here about how to use them.
