Re: Compressor working during disabled?
You are absolutely allowed to charge the tanks prior to a match starting, but like he said, you have to enable the robot.
The disable mode is specifically designed so that running motors is impossible. Usually teams will charge the compressor with the battery they last played on and swap batteries in queue right before they bring the robot onto the field |
Can we run a bypass switch so we can charge the compressor while we're in the queue without enabling the robot?
No, this would make it possible to charge the system past 120psi. This is why it is required to use the the roboRIO, PCM and pressure switch to control the compressor (even if it is not located on the robot).
try programming a "test" program for the compressor switch to test on the drivers station before match to charge and dont forget to swap batteries
No, but you can start the compressor from test mode if you don't want the robot to execute either autonomous or teleop commands while you charge the tanks.
#7
Thanks all.
