Go to Post Learn all about the alternatives, and choose wisely; don't rush the decision--this is too important to your success to make a mistake. - Tristan Lall [more]
Unread 15-02-2015, 14:21
Jtbillick Jtbillick is offline
FRC #4780
Jtbillick is an unknown quantity at this point
Robot Code disappearing in Driver Station
Hey, I'm from team 4780 and I've been having an issue making our robot drive. This is the first time my team has tried to run code from eclipse and I followed the steps on screenstepslive. The code builds successfully and when I go into the driver station the communications, joysticks, and robot code is green. When I hit enable, the robot code turns red and it gets disabled. I'm not getting any errors from anything. Can anyone tell me how i can fix this? Thanks in advance.
Unread 15-02-2015, 14:23
Arhowk's Avatar
Arhowk Arhowk is offline
FiM CSA
AKA: Jake Niman
Re: Robot Code disappearing in Driver Station
Are you sure you're not erroring out in the Riolog? Make sure the Riolog displays "Launching (bunch of wierd symbols)" to ensure you have communication. Other than that, the most likely offender would be a null pointer exception which should display on the driver station. If you're about tog get System.out.println messages, trace through your code and identify which section errors out and you might see that you forgot to initialize a motor or the like.
Unread 15-02-2015, 17:34
FRC #4780
Okay so I reconfigured the bridge and ran the program again. This time I did get errors in the riolog. Click image for larger version
ID:	18385 can anyone help me with this?
Unread 15-02-2015, 17:54
Dartmouth 2020
AKA: lopsided98
FRC #2084 (Robots by the C)
This error is usually caused by changing the package or name of the robot class after the project was created.
Make sure you build.properties file in the project folder has the correct package and Robot class name.
Unread 15-02-2015, 18:01
FRC #4780
What is the correct package and Robot class name? Sorry, I'm the only programmer on my team and this is my first year doing this.
Unread 15-02-2015, 18:06
Dartmouth 2020
AKA: lopsided98
The correct name depends on how your project is setup. The Robot class is the one that contains the robotInit(), teleopInit(), teleopPeriodic() and other methods (assuming you are using iterative or command based). The package name is the text after the package declaration at the beginning of the Robot class.
For example, my robot class is called "Robot" and its first line is:
package org.usfirst.frc.team2084.CMonster2015;
so my build.properties file has these lines:
package=org.usfirst.frc.team2084.CMonster2015
robot.class=${package}.Robot
