Go to Post Oh geez your using math. I never touched the stuff myself.:o - Koko Ed [more]
Unread 15-02-2015, 17:35
Mbudgery Mbudgery is offline
FRC #2612
Mbudgery is an unknown quantity at this point
Encoder Wiring with RoboRio
Hello,
I've searched the internet and some threads but I'm struggling to find a wiring diagram with the encoders and Roborio (pins on encoder vs pins in Roborio). Can someone please share this with us. If someone could reply quickly it would be appreciated. Sorry for asking such a simple question.... Thank you.
I accidentally posted this to another thread also - sorry.
Michael
Unread 15-02-2015, 17:46
Taylor Hawkins Taylor Hawkins is offline
2386 BCHS Trojans
FRC #2386 (Trojans)
Taylor Hawkins is an unknown quantity at this point
Re: Encoder Wiring with RoboRio
Hello,
Can we get some more information, What encoders are you using? How many pins do you have on the encoders.
Generally speaking, depending on the encoder your going to have 4 wire, (Positive, Negative, Signal A, Signal B). Encoders are digital inputs for the Roborio to use. The positive and negative pins will go to the positive and negative pins on the roborio, The signal A, will go to the signal pin of the DIO slot. The same thing is true for the signal B however that wire will go to the signal pin of a different DIO slot.
Using the 2 signals that the encoder gives you, you can determine the direction that the encoder is rotating and the speed of rotation.
Taylor
Unread 15-02-2015, 18:11
http://www.chiefdelphi.com/forums/sh...34#post1444634
Unread 15-02-2015, 19:04
FRC #2612
Thank you, we've got them working! Sorry for such the trivial question. Thank you.
Unread 16-02-2015, 10:27
one_each one_each is offline
FRC #4057 (KB Bots)
one_each is an unknown quantity at this point
As a side note, one of our students thought of a nice way to make the connectors. For our encoders, we needed +5v, gnd and two signals. Instead of making two 3x1 connectors, they used a 4x2 (as I recall) and a 4x1 then used heat shrink tubing to make one connector that fits over two DIO ports.
