Go to Post Anything worth analyzing is worth over-analyzing. And anything worth over-analyzing is worth hyper-analyzing. Ready, go! - Michael Hill [more]
Unread 15-02-2015, 16:33
WillNess's Avatar
WillNess WillNess is offline
Programmer
AKA: Will Ness
FRC #4944 (The Hi Fives)
WillNess is just really niceWillNess is just really niceWillNess is just really niceWillNess is just really nice
Compressor working during disabled?
My team is using Java, and we need the compressor to work during disabled. We tried putting code in disabled periodic, but it does not work. Has anyone else experienced this problem?
Also, is it legal to charge our tanks while queuing up for a match, or while in the pits?
Outreach Lead // Lead Programmer // Junior
2014 FRC:
Rookie Allstar, Highest Rookie Seed & Semifinalist @ Utah
Rookie Allstar, Highest Rookie Seed & Semifinalist @ Colorado
2015 FRC:
Creativity In Engineering & Semifinalist @ Arizona West
Unread 15-02-2015, 16:46
Dartmouth 2020
AKA: lopsided98
FRC #2084 (Robots by the C)
Re: Compressor working during disabled?
You cannot run the compressor while the robot is disabled. If you want to charge the tanks in the queue, you need to tether the robot and enable it.
Unread 15-02-2015, 17:07
BBray_T1296's Avatar
I am Dave! Yognaut
AKA: Brian Bray
You are absolutely allowed to charge the tanks prior to a match starting, but like he said, you have to enable the robot.
The disable mode is specifically designed so that running motors is impossible.
Usually teams will charge the compressor with the battery they last played on and swap batteries in queue right before they bring the robot onto the field
Unread 15-02-2015, 18:11
WillNess's Avatar
Programmer
AKA: Will Ness
Can we run a bypass switch so we can charge the compressor while we're in the queue without enabling the robot?
2014 FRC:
2015 FRC:
Unread 15-02-2015, 18:13
Chris_Ely's Avatar
Chris_Ely Chris_Ely is online now
AKA: luckof13
FRC #3414 (HackBots)
Chris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond repute
No, see rule R69.
Originally Posted by R69
The compressor (permitted per R68) may be located off-board, however the compressor must still be controlled and powered by the ROBOT.
2013: Waterford Finalist, Livonia Winner, MSC Quarterfinalist, Curie Division
2012: Waterford, Northville, Livonia
2011: Waterford Finalist, Livonia
2010: Ann Arbor Rookie Inspiration Award, Troy
Mechanical Engineering Student,
Michigan Technological University
Unread 15-02-2015, 18:15
Dartmouth 2020
AKA: lopsided98
No, this would make it possible to charge the system past 120psi. This is why it is required to use the the roboRIO, PCM and pressure switch to control the compressor (even if it is not located on the robot).
Unread 15-02-2015, 22:19
snoman's Avatar
snoman snoman is offline
FRC #3275 (Accelerators 3134 & Regulators 3275)
snoman is a splendid one to beholdsnoman is a splendid one to beholdsnoman is a splendid one to beholdsnoman is a splendid one to beholdsnoman is a splendid one to beholdsnoman is a splendid one to beholdsnoman is a splendid one to behold
try programming a "test" program for the compressor switch to test on the drivers station before match to charge and dont forget to swap batteries
Coach of the Cass Lake Bena Regulators 3275 (Boys)and mentor Accelerators 3134(Girls)
https://www.facebook.com/accerleratorsandregulators/
https://www.youtube.com/channel/UCQU...Cr8I4wezAbMefA
Unread 15-02-2015, 23:05
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
No, but you can start the compressor from test mode if you don't want the robot to execute either autonomous or teleop commands while you charge the tanks.
Unread 15-02-2015, 23:35
WillNess's Avatar
Programmer
AKA: Will Ness
Thanks all.
2014 FRC:
2015 FRC:
