Go to Post You can't expect a situation to get better if you don't make an attempt to confront it. - AndyB [more]
Unread 15-02-2015, 19:08
pastelpony's Avatar
pastelpony pastelpony is offline
Programmer/Electrical
AKA: Zach M
FRC #3525 (Nuts and Bolts of Fury)
pastelpony will become famous soon enough
Using two cameras in LabVIEW
I have not an idea on how to implement two cameras. I have tried a solution posted here to no avail. Would anyone be able to show an example of doing this?
I want to hot swap between cameras during a match and we are trying to use two Axis cameras.
Team 3525 Head Programmer (2014- ) - Java (Formerly LabVIEW)
Unread 21-02-2015, 23:30
BaconEater707 BaconEater707 is offline
Head Programer
FRC #2424 (Robot Mafia)
BaconEater707 is an unknown quantity at this point
Re: Using two cameras in LabVIEW
t=133771http://www.chiefdelphi.com/forums/sh...d.php?t=133771
here is an example that another team used to switch between two cameras using DB button 1. if you would be a little more specific as to what you are wanting to do it would be more accurate as to accomplish what you need to be done
the working code is the second post from the bottom in an attachment download
Unread 22-02-2015, 00:10
pastelpony's Avatar
AKA: Zach M
The post in my hyperlink has the same code referenced in that post. Thank you for your concern, though.
