Using two cameras in LabVIEW
I have not an idea on how to implement two cameras. I have tried a solution posted here to no avail. Would anyone be able to show an example of doing this?
I want to hot swap between cameras during a match and we are trying to use two Axis cameras. Last edited by pastelpony : 15-02-2015 at 22:00. |
Re: Using two cameras in LabVIEW
t=133771http://www.chiefdelphi.com/forums/sh...d.php?t=133771
here is an example that another team used to switch between two cameras using DB button 1. if you would be a little more specific as to what you are wanting to do it would be more accurate as to accomplish what you need to be done the working code is the second post from the bottom in an attachment download |
