Go to Post No! I will not be an enabler for this madness. Go outside. See a movie. Read a book. LIVE!!!! - Herodotus [more]
Unread 15-02-2015, 19:41
bharrison6 bharrison6 is offline
FRC #3843
bharrison6 is on a distinguished road
CAN Jaguar
This is our first year using CAN. Jaguar is showing the diagram as needing CAN high and CAN low same as the SRX but it also ask for a ground. Can you just wire the directly into your ground that goes to your PDB to power the Jaguar? Thanks for the help.
Bryant
Unread 15-02-2015, 20:37
Re: CAN Jaguar
No need to wire the ground on the CAN connection.
Unread 15-02-2015, 20:54
pagoglia pagoglia is offline
FRC #4203
pagoglia is an unknown quantity at this point
Re: CAN Jaguar
I believe you need to terminate the daisy chain at the roborio and the PDP. we are using 4 SRX's and 3 jags and it works fine
