Thread Tools |
Rating:
Display Modes |
#12
Re: Unhandled exception instantiating robot: No Robot Code
I had the same error for a while. If you find that the DS is telling you to look in RobotBase.java, then it is an error on your end. Try checking all pwm channels that you are using and maybe changing them out. I'm not sure if there is a specific reason why you are using higher numbered pwm channels. But, 0-3 should work perfectly.
