Go to Post If the world was like ChiefDelphi, people would be more eager to help out, offer advice and encourage each other to better things... not a bad world, that. - MissInformation [more]
Unread 13-02-2015, 23:07
shindigo shindigo is offline
AKA: Mike Parker
FRC #0102
shindigo is an unknown quantity at this point
Counting up and down with a switch
Hi We are using counters with switches on digital inputs to check for rapid changes in the switch. We would like the counter to count up when the switch goes from unpressed to pressed and count down (to negative numbers) when it goes
from pressed to unpressed. So far the counter appears to only count up on either state change.
Any thoughts about how to get it to count down when the switch is released?
mp
Unread 13-02-2015, 23:52
GeeTwo's Avatar
GeeTwo GeeTwo is online now
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
Re: Counting up and down with a switch
If you want a switch that counts both up and down, you really need something like a quadrature encoder, or a gray code encoder. Either of these has at least two separate switches. The simplest quadrature encoder is for rotation, and has one switch "on" for angles between 0 and 180 degrees, "off" for 180 to 360. The other switch is rotated 90 degrees, so it will be "on" for 90 to 270 degrees, and "off" for 270 through 0 to 90 degrees. With this sort of setup, you can tell which way the wheel is rotating based on which switch is "leading" the other towards each state. If the first switch "leads", rotation is in the positive direction, if the second switch "leads", rotation is in the negative direction.
I'll leave gray code for you to google.
Unread 14-02-2015, 23:45
mshafer1 mshafer1 is offline
Programming Mentor
AKA: Matthew Shafer
FRC #3937 (Breakaway)
mshafer1 is an unknown quantity at this point
As GeeTwo stated, something more is really needed for what you are saying, it is possible to either put two switches, or the encoders that he suggested.
I am attaching a snippet that would count up and down as described, - note that it will go 1 or 0 always.
I am also attaching a snippet of what it could look like with the second switch.
I don't have access to LabVIEW for FRC right now, so I am posting a vi that could have the switch read wired into it. I have made it in the form of an FGV, but the point is just the memory of the last value should be used (through either shift register or feedback node)
ID:	18363  Click image for larger version
Unread 15-02-2015, 12:16
jhersh jhersh is offline
National Instruments
AKA: Joe Hershberger
FRC #2468 (Appreciate)
mp
You need to construct the counter in Up/Down mode.
myCounter.setUpDownCounterMode();
Then set the up source to the channel with a rising edge and the down source to the channel with a falling edge.
myCounter.setUpSource(myDigitalIn);
myCounter.setUpSourceEdge(true, false);
myCounter.setDownSource(myDigitalIn);
myCounter.setDownSourceEdge(false, true);
Unread 15-02-2015, 13:07
Zaque Zaque is offline
FF: Bobo Brigade
AKA: Zachary H.
FRC #3352 (Flaming Monkeys)
Zaque has a spectacular aura aboutZaque has a spectacular aura aboutZaque has a spectacular aura about
Not to be rude, but this is the Java sub-forum, so some who do not have experience with LabVIEW may not be able to make heads or tails of the code you posted. If I get time I may be able to translate what you posted into Java pseudocode though .
Zaque (Zach) H.
President
Programming/Electrical Lead
Unread 15-02-2015, 14:35
Programming Mentor
AKA: Matthew Shafer
Thanks for pointing that out, Zaque. I guess I got a little ahead of myself. This is still a generic counter utility based on edges of a boolean input that could come from a DIO read, but I am sure there are other ways (like the one posted by jhersh)
To accomplish an equivalent of what I posted in Java, it would require static variables. i.e.
class Counter
private static boolean LastUpCount;
private static boolean LastDownCount;
private static int count;
public static int counter(boolean upCounter, boolean downCounter)
if(upCounter && !LastUpCount)
count++;
if(downCounter && !LastDownCount)
count--;
LastDownCount = downCounter;
LastUpCount = upCounter;
return count;
Unread 15-02-2015, 21:58
AKA: Mike Parker
FRC #0102
Thanks everyone for all the replies. The Java code that sets the up and down source makes the most sense to me so will try that first. I'll report back my findings.
