Go to Post Dangit Jim, we are engineers not politicians. - Andrew Schreiber [more]
Thread Tools Rating: Thread Rating: 7 votes, 5.00 average. Display Modes
Unread 15-02-2015, 16:16
ashweeeeeeeeeen ashweeeeeeeeeen is offline
ashweeeeeeeeeen is an unknown quantity at this point
Pneumatics not working properly. Help rookies, please!
We just got our pneumatics for our claw working yesterday, and they seem to work fine, except that the cylinders randomly open and close very quickly. We are using Vex Pro single acting solenoids on a 3 output base mount.
One of our members thinks that this happens because the solenoids lose power briefly.
Do you have any ideas?
Help us pls.
Unread 15-02-2015, 16:22
Foster Foster is offline
Engineering Program Management
VRC #8081 (STEMRobotics)
Foster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond repute
Re: Pneumatics not working properly. Help rookies, please!
For us to help you, you need to help us:
How are the pneumatics wired?
What make you think they are powering off/on
What is the robot code written in?
Can we see the code?
Can we see pictures of the wiring and the claw?
How is the claw activated? (Button, joystick, etc.)
Are there sensors that control the claw open / close states.
Do you have an onboard compressor?
Is it keeping the pressure up to 60 PSI?
Anything you can tell us past you are a rookie team and in a panic helps.
Foster - VEX Delaware - 17 teams -- Chief Roboteer STEMRobotics.org
2010 - Mentor of the Year - VEX Clean Sweep World Championship
2006-2016, a decade of doing VEX, time really flies while having fun
Downingtown Area Robotics Web site and VEXMen Team Site come see what we can do for you.
Unread 15-02-2015, 17:08
We think that its powering off then on because in the unpowered state the pneumatics keep the claw opened, and the claws open then close without us giving it the command.
The robot code is written in Java and we are using eclipse.
I do not have access to the code.
The claw is activated with Attack 3 joystick buttons.
We do not have sensors or an onboard compressor, and the pressure is maintained at 60 PSI.
Photos are attached.
ID:	18380  Click image for larger version
ID:	18381  Click image for larger version
ID:	18382  Click image for larger version
ID:	18383  Click image for larger version
Unread 15-02-2015, 17:19
The Java code would really be helpful.
Can you do a flow of what happens (like this
Robot powered off, tanks full, claw is opened
Robot powered on, claw open
Robot gets enabled, claw closes
Using the joystick, claw will open and close
If claw is closed when we disable the robot the claw does not move
(This is all made up, but we are looking for details we can't see, so you need to report back as much detail as you can)
What is your team number and where are you, there may be a team close that can help.
Unread 15-02-2015, 18:01
rich2202 rich2202 is offline
FRC #2202 (BEAST Robotics)
Check to make sure the voltage of the solenoids matches the PCM. If you have 24 volt solenoids, and the PCM is set for 12 volts, you could get random, or no, action.
Unread 15-02-2015, 20:38
I'm done for the night, see what answers you can get. you have about 28 hours to go.
Unread 15-02-2015, 20:40
We have a video of the failure happening: http://youtu.be/LFC2dyT4D04
We also have a video of the solenoid status lights turning off when the failure occurs. We will be posting this shortly.
Unread 15-02-2015, 21:08
Here is the other video: http://youtu.be/2kFg81dtRwg
Unread 15-02-2015, 22:07
snoman's Avatar
snoman snoman is offline
FRC #3275 (Accelerators 3134 & Regulators 3275)
snoman is a splendid one to beholdsnoman is a splendid one to beholdsnoman is a splendid one to beholdsnoman is a splendid one to beholdsnoman is a splendid one to beholdsnoman is a splendid one to beholdsnoman is a splendid one to behold
did the compressor kick on before or after the arms opened?
Coach of the Cass Lake Bena Regulators 3275 (Boys)and mentor Accelerators 3134(Girls)
https://www.facebook.com/accerleratorsandregulators/
https://www.youtube.com/channel/UCQU...Cr8I4wezAbMefA
Unread 15-02-2015, 22:25
Gregor's Avatar
Gregor Gregor is offline
#StickToTheStratisQuo
AKA: Gregor Browning
Are you using a battery in need of a charge? When the battery gets low the Roborio shuts everything off (which returns single solenoids to their default state) to protect a radio reboot.
FRC 2011-xxxx Volunteer
How I came to be a FIRSTer
<Since 2011
Unread 15-02-2015, 23:59
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
I can't see enough detail in the videos to see your wiring or even the lights that are going out. [list][*]Are the solenoid status lights you referring to the ones on the PCB, or something on the solenoid itself? [*]Are these single solenoid valves (with a spring return) or doubles (which will only switch based on positive electrical signal)?[*]If they are singles, the most likely case is a loss of voltage causing a PCB brown out. This happens when your motor is running, so this makes sense. Have you been tracking the voltage? I see that in 12V mode, the PCB just passes battery voltage to the solenoids; in 24V it is regulated. I didn't find the brownout voltage for the PCB itself.[*]If it's not some sort of brownout, it may be a loose connection anywhere from the PDP to the solenoid actuator somewhere. It may also be a software issue, though this seems unlikely. If you can't find any electrical issue, I would suggest creating a smart dashboard widget to monitor the programmed state of each solenoid valve.
Unread 16-02-2015, 07:35
It looks like a battery charge problem. Is the battery fully charged? What does the dashboard voltage show.
It looks like the elevator part is moving up and down when it happens. Does the power th hit happen only when you are moving the elevator?
Unread 16-02-2015, 12:43
I'll get burned, but "BUMP* to get this in the top. You guys have the day to work, what are you finding out?
OB "Why do you care?" Its scary to be in a high school physics classroom with no idea what to do. Or so I've heard
The last 48 hours are the worst in most rookie teams lives. Second is when they roll this robot onto a field in 11 days....
Unread 16-02-2015, 14:06
mshafer1 mshafer1 is offline
Programming Mentor
AKA: Matthew Shafer
FRC #3937 (Breakaway)
mshafer1 is an unknown quantity at this point
Just looking at the video, I'm not sure if it's a battery or program issue, could you post your code?
Unread 16-02-2015, 17:29
One last bump since it is after school on the left coast....
