Re: Limit switch help
Also, check that the switches are working. Depending on your specific setup, a generic way to include a monitor of Switch.get() on your smart dashboard. Then unplug your motors but otherwise run the robot. Then,
Are you limit switches wired correctly? the switch needs to be wired from signal too ground. the signal pin is held high until you ground it. so the value that you read will be inverted. you either need to rewire the switch, or put a not in front of the limit switch, such as
If(!limitswitch.Get())
motor.Set(.5);
Wait(sometime);
motor.Set(0);
Is the Wait() in WPIlib multi-thread friendly? Not being sure, I have advised our programmers against using it, but depending on somewhat more histrionic timeout measures.
It's multi-thread friendly, but there's no additional thread here. I think he's ok to do the Wait (small) at the moment - first things first ... an ability to know the switch is working right. I'd suggest not worrying about the motor control yet. I'd say use the smart dashboard to put the value of the limit switch up on the dashboard and see it flitter from 1 to 0 when it is closed and opened.
SmartDashboard::PutNumber("Switch1", limitswitch.Get());
