Go to Post FIRST always talks about grandmothers and making them proud. So FIRST---you made my grandmother proud. - Collin Fultz [more]
Unread 15-02-2015, 20:01
thatprogrammer's Avatar
thatprogrammer thatprogrammer is offline
AKA: Ahad Bawany
no team (None)
thatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond repute
Need Assistance with making autonmous work.
Hey, in our auto, we need two limit switches to be pressed. After they get pressed, the robot would need to go back. The distance code works very well, but I can't seem to get it to correspond to a limit press. Also, the autonomous height was reported as 0 before, but I MIGHT have fixed that. (I had noticed a missing variable, never tested the elevator after that)
#include "WPILib.h"
class Robot: public IterativeRobot
private:
	//Initializing livewindow
	LiveWindow *lw;
	//Initializing stick
	Joystick *stick, *Joy, *OtherJoy;
	//Initializing the Chassis parts
	Talon *kFrontLeftMotor;
	Talon *kFrontRightMotor;
	Talon *Elevator;
	RobotDrive *robot;
	Relay *Fan;
	DoubleSolenoid *shifter;
	Encoder *ChassisEnc;
	Encoder *OtherEnc;
	AnalogInput *ElevatorEnc;
	DigitalInput *LightLimit, *OtherLightLimit;
	Solenoid *Light, *OtherLight;
	//Initializing the values for Cheesy Drive
	float Rotation;
	float Acceleration;
	float rightMultiplier;
	float leftMultiplier;
    double automode;
    Gyro *gyro;
    bool robottime;
    double Angle;
    DoubleSolenoid *ElevSol;
    bool robotdrive;
   double Kp = 0.08;
   DigitalInput *Limit, *TopLimit, *OtherLimit;
   PIDController *ElevatorPID;
   double ElevatorKp;
   double ElevatorKd;
   double ElevatorHeight;
   double HeightError;
   double HeightSum;
   double Goal;
   double Out;
   double threshold;
   double numRotations;
   double lastAngle;
   double absAngle;
   double ActualRotation;
   bool Stop;
   bool TopStop;
  double DistancePerNum;
   double LastElevatorHeight;
   double Power;
   bool ShiftOpened;
   bool Goto;
   double SuperRotation;
   double Ultra;
   bool Lighton;
   bool OtherLighton;
   bool ElevSaftey;
	void RobotInit()
		SmartDashboard::init();
		lw = LiveWindow::GetInstance();
		stick = new Joystick(0);
		Joy = new Joystick (2);
		OtherJoy = new Joystick(1);
		kFrontLeftMotor = new Talon(0);
		kFrontRightMotor = new Talon(1);
		Elevator = new Talon (2);
		robot = new RobotDrive(kFrontRightMotor, kFrontLeftMotor);
		Fan = new Relay (3);
		/* Setting the shifter as a DoubleSolenoid
		 * Because we're using both pistons off of
		 * one Double Solenoid
		shifter = new DoubleSolenoid (0,1);
		ChassisEnc = new Encoder (0,1, false, Encoder::EncodingType::k4X);
		OtherEnc= new Encoder (8,9, false, Encoder::EncodingType::k4X);
        ElevatorEnc = new AnalogInput (3);
		//Setting it so the fan is off by default
		Fan->Set(Relay::kOff);
		//Setting the Rotation and Accel values
		Rotation = stick->GetRawAxis(1);
		Acceleration = stick->GetRawAxis(3);
	    /*Setting the multipliers
	     * so that they don't allow
	     * a robot to go full forward
	     * while going full turn
		rightMultiplier = Rotation + Acceleration;
		leftMultiplier = Rotation - Acceleration;
		//Setting the shifter to Low Gear
		shifter->Set(DoubleSolenoid::kReverse);
		robot->SetInvertedMotor(RobotDrive::kFrontLeftMotor, true);
		robot->SetInvertedMotor(RobotDrive::kFrontRightMotor, true);
		ChassisEnc->SetDistancePerPulse(.084);
		OtherEnc->SetDistancePerPulse(.084);
	gyro = new Gyro (1);
	Angle = gyro->GetAngle();
	if (stick->GetRawButton(1))
			automode = 1;
		if (stick->GetRawButton(2))
			automode = 2;
		} else {
			automode = 0;
	SmartDashboard::PutNumber("Auto:", automode);
gyro->InitGyro();
ElevSol = new DoubleSolenoid (2,3);
gyro->InitGyro();
Limit = new DigitalInput(7);
TopLimit = new DigitalInput(3);
OtherLimit = new DigitalInput(2);
DistancePerNum = .05;
Goto = false;
Goal = 0;
Light = new Solenoid (4);
OtherLight = new Solenoid(5);
LightLimit = new DigitalInput(4);
OtherLightLimit = new DigitalInput (5);
//Out = ElevatorKp *HeightError + ElevatorKd *HeightSum;
//Out = (.5);
//ElevatorPID = new PIDController(0.5, 0.0, 0.0, ElevatorEnc, Elevator);
//ElevatorPID->Enable();
	void AutonomousInit()
		gyro->Reset();
kFrontRightMotor->SetSafetyEnabled(false);
kFrontLeftMotor->SetSafetyEnabled(false);
ChassisEnc->Reset();
threshold = 340;
absAngle = ElevatorEnc->GetVoltage() * 72;
if ( absAngle- lastAngle < -threshold) {
          numRotations++;
        	   } else if (absAngle - lastAngle > threshold){
        		   numRotations--;
if (numRotations<0)
	numRotations = 0;
ActualRotation = ((340 * numRotations) + absAngle)- 300;
		        LastElevatorHeight = ElevatorHeight;
		        HeightError = Goal - ElevatorHeight;
		        HeightSum = ElevatorHeight - LastElevatorHeight;
		        ElevatorKp = .75;
		        ElevatorKd = .0;
		        SuperRotation = (360 * numRotations) - absAngle;
		        Power = ElevatorKp*HeightError + ElevatorKd*HeightSum;
		        ElevatorHeight= (ActualRotation/37.24)  ;
		        		if (ElevatorHeight < 0){
		        			ElevatorHeight =0;
		        		ElevSol->Set(DoubleSolenoid::kForward);
	void AutonomousPeriodic()
		bool OtherDrive;
		          numRotations++;
		        		   numRotations--;
					ElevatorHeight =0;
				Ultra = ((ActualRotation + absAngle - 600) + 4);
				ActualRotation = ((threshold * numRotations) + absAngle)- 300;
				        ElevatorKp = .75;
				        ElevatorKd = .0;
		SmartDashboard::PutNumber("Angle", gyro->GetAngle());
		SmartDashboard::PutNumber("AutoHeight", ElevatorHeight);
		double Distace = ChassisEnc->GetDistance();
		float Angle = gyro->GetAngle();
        bool turner;
        bool Grab;
        bool Auton1;
        int Driveto;
		bool ElevSaftey;
		int DriveBack =0;
        Auton1 = true;
        if (OtherLimit->Get()||TopLimit->Get())
        	ElevSaftey = true;
        } else {
        	ElevSaftey = false;
        //bool Auton2;
        //bool Auton3;
        if (Goto==true)
                		Elevator->Set(Power);
                		if (Power > .68){
                			Power = .68;
                		if (Power < -.68)
                			Power = -.68;
        if (Auton1 == true){
        	 if (OtherLimit->Get() || TopLimit->Get())
        	        	ElevSaftey = true;
        	        } else {
        	        	ElevSaftey = false;
        	 if (ElevSaftey == true)
        		 Elevator->Set(0);
        		 Goto = false;
  Grab = true;
  if (Grab == true){
 Driveto = 0;
  if (LightLimit->Get() || OtherLightLimit->Get()){
//	  Wait(2);
	  DriveBack= Driveto + 1;
	  Goto = true; }
	  if (Goto == true){
		  Grab = false;
       if (Grab == false)
    	   if (DriveBack>0){
    		   DriveBack = 1;
  if (Grab == false && Goto == true)
	 /* if (Goto==true){
		  Goal =5; }
	          else if (Goto== true && ElevSaftey == true)
	        	  Elevator->Set(0);
 	        	ElevSaftey = true;
 	        } else {
 	        	ElevSaftey = false;
 		 Elevator->Set(0);
 		        		 Goto = false;
	  if (ElevatorHeight>= Goal){
	    	Driveto = true;
	Goto= false;
	  if (ElevSaftey== true && Driveto == true)
		  Elevator->Set(0);
		  Goto = false;
	  } else if (ElevSaftey == true && Driveto == false)
		  Goto = true;
     	        	ElevSaftey = true;
     	        } else {
     	        	ElevSaftey = false;
     		 Elevator->Set(0);
     	 		        		 Goto = false;
  if (DriveBack > 0)
	  if (Distace > -108 ){
	  	  		  robot->Drive(.5, -Angle*Kp);
	  	  		  Goto = false;
	  if (Distace <=108 && DriveBack >0 )
		  robot->Drive(0, 0);
		  DriveBack = 0;
		  OtherDrive = true;
		 /* if (ElevSaftey == true)
			  Elevator->Set(0);
			  OtherDrive = true;
		  } else {
			  Elevator->Set(-.5);
  if (OtherDrive == true){
	  if (Distace < 112)
		  robot->Drive(.5, 0);
	  } else if (Distace > 112)
		  robot->Drive(0, 0);
Unread 15-02-2015, 20:58
Christopher149 Christopher149 is offline
FRC #0857 (Superior Roboworks) FTC 10723 (SnowBots)
Christopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond repute
Re: Need Assistance with making autonmous work.
Just to be sure, do you know if the switches work? They should have a connection between signal and ground on a DIO port.
2015-present: FTC 10723 mentor
2012-present: 857 mentor
2008-2011: 857 student
2015: Industrial Design, Excellence in Engineering, District Finalist, Archimedes Division (#6 alliance captain)
2014: Judges Award, District Engineering Inspiration, District Finalist, Galileo Division
Unread 15-02-2015, 21:45
AKA: Ahad Bawany
no team (None)
They work 100% in teleop. Also, is there a way to make the robot wait until the piston is done opening before it starts with the rest of auto?
Unread 16-02-2015, 00:46
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
Originally Posted by thatprogrammer View Post
.. is there a way to make the robot wait until the piston is done opening before it starts with the rest of auto?
You'll need some sort of sensor to detect when that happens. If your pistons have ferromagnetic plates, you can place magnetic switches on the outside of the pistons to detect when the piston is "done". These switches are usually provided by Bimba with the FIRST choice cylinders, or can be purchased easily enough. If your pistions are non-magnetic, a limit switch is your best bet. These can be triggered mechanically or through magnetism, or even optically. Figuring out what style of limit switch you need is very dependent on your application. If you can't think of how to place a limit switch on your device, I suggest going to google images and searching for "limit switch". Look at the pictures until something looks like it could work, or 100 pictures, whichever comes first.
FWIW, the 3946 robot has three distinctive styles of limit switch this year; two optical, six push-button, and four lever arm with roller.
Unread 16-02-2015, 00:49
rich2202 rich2202 is offline
FRC #2202 (BEAST Robotics)
Two options:
1) Put a magnetic sensor on the piston. Then you can tell when it has moved to the desired location.
2) Put a time delay, and wait 1 second, or however long it takes the piston to move.
