Go to Post that is one of the funniest non-photoshoped pictures of my father i have seen... - Lil' Lavery [more]
Unread 16-02-2015, 01:46
dtengineering's Avatar
AKA: Jason Brett
pic: 5742: Capstan and String
Unread 16-02-2015, 01:48
Oblarg Oblarg is offline
AKA: Eli Barnett
Re: pic: 5742: Capstan and String
I like this, a lot. Extremely simple, easy-to-maintain, and a cool application of a mechanism not seen very often. I also dig the simplicity of your linear bearing system.
"The breakfast of champions!"
Unread 16-02-2015, 16:35
AKA: Jason Brett
Thanks! We actually got pretty lucky. The motor has enough torque to lift two totes and a bin (plus the rather hefty lift mechanism itself) but not quite enough torque to pull the lift mechanism apart. Okay... it wasn't luck that we had enough torque to lift the stack... that was a bit of physics and the Taigene motor power data. It was what would happen when we hit the top and the bottom of the lift that worried me. We had originally planned to add limit switches top and bottom (and if the team has time, I expect they will) but they are not required.
On the other hand, the taigene backdrives easier than I remember, so they actually have to use a bit of current to hold it in position. So long as they only use a little bit of current it seems to work okay. Cramming it full power on and stalled at the very top of the lift will trip the breakers and the lift and load will slowly descend. My faith in worm gear lifts remains solid!
It would have been nice to add a few more features... as I said to the team, "You're in really good shape for week four of build season!" But they are also in pretty good shape for week six of their rookie build season. They have a machine that moves reliably and can contribute to their alliance.
Jason
Unread 16-02-2015, 23:28
gp2013 gp2013 is offline
FRC #2013 (Cybergnomes)
gp2013 will become famous soon enoughgp2013 will become famous soon enough
Nice. Looking forward to working with you guys in Calgary.
