Go to Post "Don't worry, it's just a prototype." - Newo95 [more]
Thread Tools Rating: Thread Rating: 9 votes, 5.00 average. Display Modes
Unread 16-02-2015, 06:43
IKE's Avatar
IKE IKE is offline
Not so Custom User Title
AKA: Isaac Rife
no team (N/A)
Re: Rookie Team Redesign
Shocks or impacts are likely what is killing your gearboxes. Every bump causes really high torque back into the arm. My recommendation is to remote the gearbox from the arm. A low pivot "hip joint" on the front side would reduce loads. Using sprockets to drive it. Or possibly setting it up as a winch off the back.
Unread 16-02-2015, 07:28
mlantry mlantry is offline
I'm back
AKA: Matthew Lantry
mlantry has much to be proud ofmlantry has much to be proud ofmlantry has much to be proud ofmlantry has much to be proud ofmlantry has much to be proud ofmlantry has much to be proud ofmlantry has much to be proud ofmlantry has much to be proud ofmlantry has much to be proud of
http://m.grainger.com/mobile/product...ler-Body-4X176
you could find a way to integrate one of these. All you need are to sides and a rubber insert it will help to absorb shock from moving around on the gearbox my team used one made from aluminum last year on our catapult reset that we kept breaking gearboxes on due to shocks from shooting, made it seem likevthe problem was never even their.
Matthew Lantry
Team 4475 2014-present
-College Mentor 2014-????
Team 1676- 2011-2014
-Mechanical 2011-2014, Subteam leader 2013-2014
-Robot Operator 2014
George G. White FLL mentor 2011-2014
“Both optimists and pessimists contribute to our society. The optimist invents the airplane and the pessimist the parachute.”
Unread 16-02-2015, 07:33
rich2202 rich2202 is offline
FRC #2202 (BEAST Robotics)
Not relevant to your question, but:
Last year, there was a lot of concern about stored energy. How much energy does your bungee cord store when fully lowered? If it is more than nominal, the Robot Inspector may make you cover the cord so, if it breaks, no one is inadvertently injured.
Unread 16-02-2015, 12:14
joelg236 joelg236 is offline
4334 Retired Mentor & Alumni
AKA: Joel Gallant
joelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond repute
It's not as much energy as it looks. The competition bot will have a good securing method to make sure the tension is constant.
All opinions are my own.
Unread 16-02-2015, 12:17
DaveL DaveL is offline
FRC #2976
DaveL is a jewel in the roughDaveL is a jewel in the roughDaveL is a jewel in the roughDaveL is a jewel in the rough
Another hardware option is the BaneBots p80 transmission with a CIM motor.
http://banebots.com/pc/P80K-S4/P80K-443-0005
They come in a variety of ratios.
Like an earlier post, I would recommend relocating the motor/transmission from the pivot point. Sprockets and chain would be my approach.
If you have or can get a drive transmission, that might be another option with reduction gearing.
Dave
Mentor 2976
Unread 16-02-2015, 12:13
AKA: Joel Gallant
A winch would limit our range of motion (since the arm needs to go all the way back for bins). I'm intrigued by the idea of reducing shock, since we have lots of spare belts and some sprockets, so it would just be a question of mounting. I'll be trying this today.
Unread 16-02-2015, 13:26
seg9585's Avatar
seg9585 seg9585 is offline
AKA: Eric
FRC #4276 (Surf City Vikings)
seg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond repute
A winch would not have to limit your range of motion. From your picture, mount the winch above the drive CIMs and attach a tension cord to the extreme back of the mechanism (where the tubing is connected). That should give you full range of motion.
My FIRST legacy:
Team 204 Student 2001, 2002 (Voorhees, NJ)
Team 1493 College Mentor 2006 - 2008 (Troy, NY)
Team 2150 Intern/Professional Mentor 2007, 2009 (Palos Verdes)
Team 4123 Lead Engineering Mentor 2012 (Bellflower, CA)
Team 4276 Engineering Mentor 2012-2016 (Huntington Beach, CA)
Unread 16-02-2015, 13:55
IKE's Avatar
IKE IKE is offline
AKA: Isaac Rife
no team (N/A)
Shock loading is a really tricky thing to improve, but awesome when you get it right. What you are looking for is something that can support your nominal load fully, but then flexes a little bit if you exceed that. Using a coupling like these spider couplings might work:
http://www.mcmaster.com/#spider-couplings/=vxqhqt
It looks like your arm has about a 3 foot reach for center of mass of a Tote. I think this would equate to about 25 ft*lbs or 300 in*lbs. I personally would size the coupling and buy 3 spiders (different material). They have urethane ones rated for 290 in*lbs, and a Buna Nitrile the same size rate for 140 in*lbs, and a Hytrel rated for 400 in*lbs. I think you might be happiest with the Buna Nitrile (I personally would order 2 of those to have a spare). I suspect that the torque rating is a Max Continuous at operating RPM, and for your application would add a nice cushion to the lifting and bumps. Should it be undersized, then the same geometry urethane would be a good alternate.
All this being said, you are outside of VEXPROs load rating for that gearbox. They do their rating chart based off of motors and ratios as the motors have the capability to apply enough torque to do damage to the gearbox in those scenarios.
http://content.vexrobotics.com/vexpr...s-20150106.pdf
IE, any of the above fixes, and you are still operating outside of the recommended limits of the gearbox.
For this, my overall recommendation would be get a new 5:1 ratio box, and rebuild it to be 50:1 ratio, and then use a chain loop for the arm. I personally like big sprockets on arms as it reduces the tension in the chain and thus compounded loading effects Something like a 36 tooth sprocket or larger attached to the arm, and then driven by a 12 to 15 tooth sprocket.
the same 300 inch*lbs needed by the arm will equate to about 150 lbs of chain tension (radius of a 36T #35 chain sprocekt is a bit over 2 inch).
