Go to Post Ahem, a climbing xerox machine. Also known as the scariest type of xerox machine this Earth has ever seen. - itsjustjon [more]
Unread 16-02-2015, 11:36
Re: Solution to Ethernet Communications Problem with roboRIO
Originally Posted by Tim Sharp View Post
If the adapter settings or DHCP only the roboRIO will not get an IP address
There appears to be a grammar error. Could you please clarify the intended meaning?
Unread 16-02-2015, 12:07
I believe that DHCP or link local should have been the default setting. Do you know if that was the case?
It is also possible to change this, if necessary, or to check it using the web configuration tool. Use a web browser and use roboRIO-team#.local as the URL. The fourth button vertically on the left is the ethernet configuration page.
Greg McKaskle
Unread 16-02-2015, 12:18
Tim Sharp Tim Sharp is offline
Tim Sharp
FRC #3959 (Morgan County Mech Tech)
Tim Sharp is a splendid one to beholdTim Sharp is a splendid one to beholdTim Sharp is a splendid one to beholdTim Sharp is a splendid one to beholdTim Sharp is a splendid one to beholdTim Sharp is a splendid one to beholdTim Sharp is a splendid one to behold
We are not sure how DHCP or local link was changed. We may have changed it inadvertently.
