Go to Post A good leader will step down so the right people are in the leadership positions, regardless of age. - Phoenix Spud [more]
Unread 16-02-2015, 13:15
SirGibbs SirGibbs is offline
FRC #5676 (Hornets)
Rookie Year: 2015
SirGibbs is an unknown quantity at this point
Build Errors
Hey guys,
after multiple errors with eclipse and my code, I got it finally but when I try to deploy the code now, I get this error:
ERROR Unhandled exception instantiating robot org.usfirst.frc.team5676.robot.Robot java.lang.IllegalStateException: Network tables has already been initialized at [edu.wpi.first.wpilibj.networktables.NetworkTable.checkInit(NetworkTable.java:45), edu.wpi.first.wpilibj.networktables.NetworkTable.setServerMode(NetworkTable.java:68), edu.wpi.first.wpilibj.RobotBase.<init>(RobotBase.java:58), edu.wpi.first.wpilibj.IterativeRobot.<init>(IterativeRobot.java:55), org.usfirst.frc.team5676.robot.Robot.<init>(Robot.java:16), sun.reflect.NativeConstructorAccessorImpl.newInstance0(Native Method), sun.reflect.NativeConstructorAccessorImpl.newInstance(NativeConstructorAccessorImpl.java:62), sun.reflect.DelegatingConstructorAccessorImpl.newInstance(DelegatingConstructorAccessorImpl.java:45), java.lang.reflect.Constructor.newInstance(Constructor.java:408), java.lang.Class.newInstance(Class.java:433), edu.wpi.first.wpilibj.RobotBase.main(RobotBase.java:197)]
I just dont know what I would need to change to make it running... here is my code:
package org.usfirst.frc.team5676.robot;
import edu.wpi.first.wpilibj.IterativeRobot;
import edu.wpi.first.wpilibj.RobotDrive;
import edu.wpi.first.wpilibj.Timer;
import edu.wpi.first.wpilibj.DoubleSolenoid;
import org.usfirst.frc.team5676.robot.XboxController;
import edu.wpi.first.wpilibj.Compressor;
import org.usfirst.frc.team5676.robot.XboxController.Axis;
import org.usfirst.frc.team5676.robot.XboxController.buttons;
import org.usfirst.frc.team5676.robot.XboxController.triggers;
public class Robot extends IterativeRobot {
	RobotDrive myDrive;
	Joystick driveStick;
	static XboxController gameStick = new XboxController(1);
	DoubleSolenoid Piston;
	static Axis LeftStick=Global.driver.LeftStick;
	static Axis RightStick=Global.driver.RightStick;
	static triggers Triggers = Global.driver.Triggers;
	static buttons DriverButtons = Global.driver.Buttons;
	static buttons OperatorButtons = Global.operator.Buttons;
	static int OperatorDpad = -1;
    public void robotInit() {
    	myDrive = new RobotDrive (1, 2, 3, 4);
    	driveStick = new Joystick(1);
    public void autonomousPeriodic() {
    public void operatorControl() {
    	while (isOperatorControl() && isEnabled()) {
    		myDrive.arcadeDrive(driveStick);
    		Timer.delay(0.01);
    public void teleopPeriodic() {
    public void moveArm()
	{	 Piston = new DoubleSolenoid(0,1 );
		if(gameStick.button[0].get() == true) {
			Piston.set(DoubleSolenoid.Value.kForward);
			System.out.println("'A' button is pressed: Piston moves forward");
	  else if(gameStick.button[1].get() ==true)
			Piston.set(DoubleSolenoid.Value.kReverse);
			System.out.println("'B' button is pressed: Piston moves backward");
		else
			Piston.set(DoubleSolenoid.Value.kOff);
    public void FrontArm()
   	{	 Piston = new DoubleSolenoid(2,3 );
   		if(gameStick.button[2].get() == true) {
   			System.out.println("'X' button is pressed: Piston moves forward");
   	  else if(gameStick.button[3].get() ==true)
   			System.out.println("'Y' button is pressed: Piston moves backward");
   		else
    public void pickerArm()
	{	 Piston = new DoubleSolenoid(4,5 );
		if(gameStick.button[4].get() == true) {
			System.out.println("LB' button is pressed: Piston moves forward");
	  else if(gameStick.button[5].get() ==true)
			System.out.println("'RB' button is pressed: Piston moves backward");
		else
    public void testPeriodic() {
Thank you in advance for any help or suggestions.
Unread 16-02-2015, 17:27
dstech dstech is offline
dstech is an unknown quantity at this point
Re: Build Errors
Well First it looks like you have a lot going on in your code with all those imports and extending a class but I would try and really pick apart that error and see if you can find that spot in "RobotBase" where it is actually messing up.
Apart from that you could try surrounding your code with a try-Catch block to handle that exception and see if that will make it happy? I may be completely off base but it's worth a shot...
Unread 16-02-2015, 17:57
FRC #5676 (Hornets)
Rookie Year: 2015
Re: Build Errors
At first thank you, well we are a complete rookie team. Oke what exactly would that do?
Unread 16-02-2015, 18:02
gbear605's Avatar
gbear605 gbear605 is offline
Scarebear
FRC #1768 (Nashoba Robotics)
gbear605 is an unknown quantity at this point
Re: Build Errors
It's saying that Network tables has already been created. Have you tried restarting the robot/RoboRIO?
If that doesn't fix it: your code look fine. The error appears (to me) to be unrelated to your code, especially since the error has to do with Network Tables, which you aren't using in your code. There's likely some other error in your electronics or your method of deploying the code.
Unread 16-02-2015, 18:05
BrighidKHeh's Avatar
BrighidKHeh BrighidKHeh is offline
FRC #3871 (Trojan Robotics)
BrighidKHeh is an unknown quantity at this point
Re: Build Errors
I'm having the same problems. Once I get to the Driver Station, I get this error message, along with no Robot Code:
ERROR Unhandled exception instantiating robot org.usfirst.frc.team3871.robot.Robotjava.lang.Clas sNotFoundException: org.usfirst.frc.team3871.robot.Robot at [java.net.URL.ClassLoader$1.run(URLClassLoader.java :372), java.net.URL.ClassLoader$1.run(URLClassLoader.java :361), java.security.AccessController.doPriveleged(Native Method), java.net.URLClassLoader.findClass(URLClassLoader.j ava:360),java.lang.ClassLoader.loadClass(ClassLoad er.java:424), sun.misc.Launcher$AppClassLoader.loadClass(Launche r.java:308), java.lang.ClassLoader.loadClass(ClassLoader.java:3 57), java.lang.Class.forName0(NativeMethod), java.lang.forName(Class.java:259), edu.wpi.first.wpilibi.RobotBase.main(RobotBase.jav a:197)]
Unread 16-02-2015, 18:35
FRC #5676 (Hornets)
Rookie Year: 2015
Re: Build Errors
Ok thank you guys, as soon as I can come into the school tomorrow I will restart the Robot and try it again, maybe reimage it. I asked several people and nobody sees a relation between the code and the error... Otherwise I will try the "try block". If that doesn't help, I don't know... Maybe one of you gets a magic idea ^^. Thank you all for your help, I will keep you up do date, maybe that also helps somebody else. If you have any more suggestions or ideas, no matter what it is, please post it...
Unread 17-02-2015, 07:58
FRC #5676 (Hornets)
Rookie Year: 2015
Re: Build Errors
Ok it has to be an code error. The default code is running. That is so incredible weird, is anybody seeing the mistake???
Unread 17-02-2015, 08:01
gbear605's Avatar
Scarebear
Re: Build Errors
When you put your code on the robot, does it work now?
Unread 17-02-2015, 08:57
FRC #5676 (Hornets)
Rookie Year: 2015
Angry Re: Build Errors
Well the default code was running,our code wasn't. I tried a second code that I wrote last night and it told me that it was running and deployed, but I got the error again but it still worked. So I started to reimage the roborio just in case and to reinstall java. Is it just me or is the one that we need missing at the download page????? The Armv 7 Linux AFP Softfp abi little endian jre? The ones that are at the oracle website aren't working. I would bet that their was a third one yesterday...
Unread 17-02-2015, 09:51
fsilberberg fsilberberg is offline
WPILib Developer
AKA: Fred Silberberg
FRC #0190
fsilberberg has a spectacular aura aboutfsilberberg has a spectacular aura aboutfsilberberg has a spectacular aura about
Make sure you're running the latest plugins. That error was fixed a few weeks ago.
Unread 17-02-2015, 10:14
FRC #5676 (Hornets)
Rookie Year: 2015
Re: Build Errors
oke I will. Its just weird because it was working yesterday.....
Unread 17-02-2015, 11:06
FRC #5676 (Hornets)
Rookie Year: 2015
Re: Build Errors
Ok the default codes are running, I still get the same error when i use my code. So it seems to be code related...
Unread 17-02-2015, 11:33
cstelter cstelter is offline
Programming Mentor
AKA: Craig Stelter
FRC #3018 (Nordic Storm)
cstelter will become famous soon enough
Re: Build Errors
Only thing that jumped out at me is you're instantiating both xbox controller and Joystick on port 1. That doesn't seem right, but likely won't lead to the problem.
Try commenting all but the drivetrain and incrementally adding in items
i.e. start with:
	RobotDrive myDrive;
	//static XboxController gameStick = new XboxController(1);
	//DoubleSolenoid Piston;
	//static Axis LeftStick=Global.driver.LeftStick;
	//static Axis RightStick=Global.driver.RightStick;
	//static triggers Triggers = Global.driver.Triggers;
	//static buttons DriverButtons = Global.driver.Buttons;
	//static buttons OperatorButtons = Global.operator.Buttons;
	//static int OperatorDpad = -1;
    		Timer.delay(0.01);
		else
   		else
		else
Hmm... as I was making suggested comments, I noticed that you are using iterative Robot, but relying on operatorControl() to actually drive. I'm not sure if/how operatorControl() is used in IterativeRobot. Normally one would put that code in teleopPeriodic and not implement operatorControl()
    		Timer.delay(0.01);
