Go to Post For example, you can make a car as safe as possible. It may get the highest safety ratings in it's class, but if you drive it off of a cliff there really isn't much you can do about that. - jmanela [more]
Go Back   Chief Delphi > Technical > Electrical > CAN
Unread 12-02-2015, 22:29
Re: Problem With Talon SRX Enabling
Originally Posted by King Nerd III View Post
There are drivers for the roboRIO that need to be installed. They will not install through Ethernet.
That's because they are USB drivers. They don't have anything to do with Ethernet.
Unread 13-02-2015, 08:32
King Nerd III's Avatar
King Nerd III King Nerd III is offline
Chief Programmer/Head of Autonomous
AKA: Isaac
FRC #1410 (The Kraken)
King Nerd III is an unknown quantity at this point
Oh! I just remembered what we figured out yesterday! The only Talons that enable during the Teleop over WiFi were the ones used in a command that is set as a default command. We have verified this by changing the default commands and the Talons do switch around. But for us this is not feasible as then the only command for an elevator moves it up and we can't have it constantly moving up.
Unread 13-02-2015, 19:41
AKA: Isaac
UPDATE: We figured out that if we connect to the robot, go to the DriverStation and click "Restart Robot Code" all the Talons will enable!
Unread 14-02-2015, 11:35
duane's Avatar
duane duane is offline
FRC #0701 (RoboVikes)
duane is an unknown quantity at this point
Send a message via AIM to duane
This seems like a programming problem then.
Just like PWM, you need to tell every speed controller what speed it should be running at all the time. Even if the speed is zero, you are responsible for continuously updating every speed controller.
Duane Murphy
Mentor - Software
Vanden Vikings FIRST Team 701
http://www.vandenrobotics.com
Unread 16-02-2015, 14:39
AKA: Isaac
We tried this. It did not fix anything, but the way we did it with the button is good enough. Turns out even if they don't say that they're enabled they still drive the motor.
Unread 16-02-2015, 15:02
That sounds like a serious and dangerous problem! Can you document it? Provide the code that runs a disabled Talon SRX, include screen captures of the web interface showing how everything is configured, and see if anyone else can reproduce it.
Unread 16-02-2015, 15:56
Jefferson Jefferson is offline
AKA: Jeff Clements
FRC #0016 (Bomb Squad)
Jefferson has a reputation beyond reputeJefferson has a reputation beyond reputeJefferson has a reputation beyond reputeJefferson has a reputation beyond reputeJefferson has a reputation beyond reputeJefferson has a reputation beyond reputeJefferson has a reputation beyond reputeJefferson has a reputation beyond reputeJefferson has a reputation beyond reputeJefferson has a reputation beyond reputeJefferson has a reputation beyond repute
I'll add a little to this thread... and hopefully it's not just confusion. I've not documented this issue elsewhere because I can't reproduce it now.
The short story: 2 of our SRXs wouldn't enable with the rest of them. One was in follower mode, the other in closed loop (but wasn't the master of the follower). This only happened when the robot was power-cycled. If we, like OP says, restarted the robot code, all SRXs enabled as expected. It was repeatable for the code we had at the time. We had to make some changes and the issue disappeared. (Un?)fortunately it went away before I could fully debug it and didn't get a commit at that point.
I know it kind of stinks, but our workaround was just to restart the code whenever we power cycled. That reliably fixed the issue.
Unread 16-02-2015, 21:49
ozrien's Avatar
ozrien ozrien is online now
Omar Zrien
AKA: Omar
Hey Jefferson, I think I have it figured out. Seems like calling joystick routines in the disabled loop has the undesired effect of causing the RIO's backend to crash/restart on power boot. It only happens once and doesn't affect much since the robot is booting up anyway. But there is a moment where when the CANTalon's object constructor's set up their messages, there is no one listening at the other end.
If you're grabbing joystick values in disabled() and using CAN Actuators I recommend calling one of the setXXX() routines on each CAN Actuator in the disabled loop. That way if this problem occurs, the code will periodically signal to the back end that those CAN objects exist and should be enabled. I reproduced your problem and tested the workaround.
So for your two CANTalons (or just do all of them), try calling set(0) in the disabled loop so that on-power-boot they get reregistered ok.
Unread 17-02-2015, 00:56
AKA: Jeff Clements
Originally Posted by ozrien View Post
Hey Jefferson, ...
Omar,
Thanks! Just to make sure: calling a Get() function should be enough, right? I'd rather not disturb some of the position control with a Set() function.
Unread 17-02-2015, 02:58
ozrien's Avatar
Omar Zrien
AKA: Omar
Gotta be a set. It will not disturb anything because it's in the disabled loop. It updates the control frame bytes, which aren't sent until after you enable.
Unread 17-02-2015, 16:09
AKA: Isaac
Could this possibly be what is causing our Talons to not enable? We don't have a disabled portion in our command based framework, but could easily add one if it would help.
Unread 17-02-2015, 19:41
ozrien's Avatar
Omar Zrien
AKA: Omar
Try it to at least rule it out.
Unread 19-02-2015, 18:10
ozrien's Avatar
Omar Zrien
AKA: Omar
More info at Talon SRX Software reference Manual section 21.18
