Go to Post No offense, but telling the Killer Bees they should do something is like telling Micheal Jordan how to dunk a basketball (or Lebron James for you young'ens who don't know who Michael Jordan is)... - Don Wright [more]
Unread 16-02-2015, 18:45
Re: CAN Talon Does Not Move in Speed Mode
Section 17.5 of the TALON SRX Software Reference Manual lists the throttle range as -1023 to +1023. A throttle of -19 is very, very small--less than 2%. You might need to increase the P value.
Note that the speed value is in encoder counts per 100 milliseconds. You will need to convert from RPM (or whatever speed units you use) based on the number of encoder counts per revolution. Note also that the encoder is always read in 4x mode, so a 250 cycle per revolution encoder is actually 1000 counts per revolution.
Unread 16-02-2015, 19:05
restouffer's Avatar
restouffer restouffer is offline
AKA: Bob Stouffer
FRC #2539 (Krypton Cougars)
restouffer is an unknown quantity at this point
Thanks for the quick reply. We have increased the P value and will give it a try as soon as the fabrication team gets done with the robot.
Unread 16-02-2015, 19:56
restouffer's Avatar
AKA: Bob Stouffer
Yep, that was our problem. I'm not used to working with numbers in the thousands, and we were a bit worried about setting the value too high. Now we know better.
Thanks for your time.
Unread 17-02-2015, 19:44
ozrien's Avatar
ozrien ozrien is offline
Omar Zrien
AKA: Omar
ozrien has a brilliant futureozrien has a brilliant futureozrien has a brilliant futureozrien has a brilliant futureozrien has a brilliant futureozrien has a brilliant futureozrien has a brilliant futureozrien has a brilliant futureozrien has a brilliant futureozrien has a brilliant futureozrien has a brilliant future
Glad you guys are up and running.
Just a guess : AppliedThrottle at -19 and ClosedLoopErr is -200, so I'm guessing Pgain was 0.1.
Unread 18-02-2015, 08:27
restouffer's Avatar
AKA: Bob Stouffer
Good guess. Changing P to 1 and speed to 400 seems to work much better.
