Go to Post My wife is in advertising, and uses a scary amount of math. They have to know how to target you and beat down your defenses, so that you buy that hamburger while driving that car while wearing those designer jeans to your favorite store. - Not2B [more]
Unread 16-02-2015, 18:34
weaversam8 weaversam8 is offline
Team Captain
AKA: Sam Weaver
FRC #4534 (Wired Wizards)
weaversam8 is a splendid one to beholdweaversam8 is a splendid one to beholdweaversam8 is a splendid one to beholdweaversam8 is a splendid one to beholdweaversam8 is a splendid one to beholdweaversam8 is a splendid one to behold
Withholding Allowance
Our team had a question on withholding allowance: Are there any limitations to what you can withhold? E.g: could a team leave the roboRIO off, or an entire lifting mechanism, and attach it before inspection at competition.
ORB Haow!
Unread 16-02-2015, 18:42
Re: Withholding Allowance
Limitations: None. However, you should be aware that the Withholding Allowance is 30 lbs of Fabricated Items, with does not include COTS items (say, the RoboRIO if it isn't mounted on a board/connected to anything). And yes, you should attach it to the robot and get it inspected before taking it on the field for a match.
Unread 16-02-2015, 18:51
You can leave off anything and everything. But the robot you bring into the pits at competition will be limited to whatever is in the bag plus up to 30 pounds of fabricated items (plus as much raw material and as many COTS components as you want).
Team Captain
AKA: Sam Weaver
Meaning that we could bring the roboRIO unattached and it would be legal AND not count for part of our withholding allowance.
ORB Haow!
Unread 16-02-2015, 18:59
matthewdenny's Avatar
matthewdenny matthewdenny is offline
FRC #6054 (Dukes)
matthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant future
Yes
Unread 16-02-2015, 19:00
Since reprogramming a roboRIO is not considered a modification, then an unmounted roboRIO is an unmodified COTS part that does not count against your withholding allowance.
Unread 16-02-2015, 19:09
rich2202 rich2202 is offline
FRC #2202 (BEAST Robotics)
Technically, if you have wires attached to the RoboRio (label the wires so you know where they go), that is considered a modification, and no longer COTS. Since it is not COTS, it would count against your 30 pounds.
The RoboRIO, without anything attached, is COTS, and thus does not count against the 30 pounds.
In either case, the RoboRio does not have to be bagged with the robot. The question is whether the RoboRio counts against your 30 pound withholding allowance.
