Go to Post If you do mentor FIRST, be an asset to your team, but know that your students will admire you all the more if you set an example and finish your own homework. - Eugenia Gabrielov [more]
Unread 16-02-2015, 20:36
JacobD's Avatar
JacobD JacobD is offline
AKA: Jacob
FRC #1672 (Mahwah Robo T-Birds)
JacobD is an unknown quantity at this point
Re: Periodic connection loss to D-link
Originally Posted by Chris_Ely View Post
When the battery voltage drops too low, the boost power supplies for the control system can no longer supply the proper voltage. To preserve battery voltage, the RoboRIO uses a staged brownout scheme that shuts down motors and other outputs. You can learn more about this here.
As a general rule, when the battery voltage drops near or below 12V when the robot is idle, you should change the battery.
The funny thing is that my robot would do this at 12.5v idle. But thanks for the information. I'll look for the light indicators next time it happens. That's assuming it my robot isn't on the field during competition.
Unread 16-02-2015, 20:40
Chris_Ely's Avatar
Chris_Ely Chris_Ely is online now
AKA: luckof13
FRC #3414 (HackBots)
Chris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond repute
It would lose connection at 12.5V, or with a nominal battery voltage of 12.5V it would lose connection under load? If the latter, your battery might not be able to hold a charge very will anymore. Is this an old battery?
2013: Waterford Finalist, Livonia Winner, MSC Quarterfinalist, Curie Division
2012: Waterford, Northville, Livonia
2011: Waterford Finalist, Livonia
2010: Ann Arbor Rookie Inspiration Award, Troy
Mechanical Engineering Student,
Michigan Technological University
Unread 16-02-2015, 23:20
JacobD's Avatar
AKA: Jacob
It has happened with 3 new batteries. So, I can say that the battery is not the problem. Don't stress over it. We can still drive for a solid 30 minutes without having any issues.
Unread 16-02-2015, 23:46
Chris_Ely's Avatar
AKA: luckof13
If you are driving 30 minutes on the same battery, you are most likely draining it down to the point where you can damage it. My team has lost several otherwise good batteries because of this.
